Gateway NV52 WiFi Card Replacement
  1. Gateway NV52 WiFi Card Replacement, Base Cover: step 1, image 1 of 1
    • Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
  2. Gateway NV52 WiFi Card Replacement: step 2, image 1 of 1
    • Lift up the base cover from the the top with your hands to a 90 degree angle.
    • Remove the base cover and place it in a safe and dry place.
  3. Gateway NV52 WiFi Card Replacement, WiFi Card: step 3, image 1 of 1
    • Remove the 3/16" screw located at the bottom left corner of the WiFi card using a Phillips #0 Screwdriver.
  4. Gateway NV52 WiFi Card Replacement: step 4, image 1 of 1
    • Locate the black and white cables attached to the WiFi card.
    • Gently wiggle the black cable until it detaches from the WiFi card.
    • Repeat the previous step for the white cable.
  5. Gateway NV52 WiFi Card Replacement: step 5, image 1 of 1
    • Gently, remove the Wifi card from its slot, and place it in a dry and safe place.
Ruben
298 Reputation
2 Guides authored
Cal Poly, Team 7-24, Regan Spring 2014 Member of Cal Poly, Team 7-24, Regan Spring 2014
CPSU-REGAN-S14S7G24
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 1,276
