Gateway NV55C49u RAM Replacement
  1. Gateway NV55C49u RAM Replacement, RAM: step 1, image 1 of 1
    • Flip the laptop bottom side up.
  2. Gateway NV55C49u RAM Replacement: step 2, image 1 of 1
    • Slide the battery lock to show the red background.
  3. Gateway NV55C49u RAM Replacement: step 3, image 1 of 2 Gateway NV55C49u RAM Replacement: step 3, image 2 of 2
    • Push the battery slider to the other side. This will automatically eject the battery.
    • You can now remove the battery.
  4. Gateway NV55C49u RAM Replacement: step 4, image 1 of 1
    • Remove the two 6.0mm Phillips #00 screws from the back cover.
  5. Gateway NV55C49u RAM Replacement: step 5, image 1 of 3 Gateway NV55C49u RAM Replacement: step 5, image 2 of 3 Gateway NV55C49u RAM Replacement: step 5, image 3 of 3
    • Remove the back cover by placing the plastic opening tool in the indention, and prying upwards.
  6. Gateway NV55C49u RAM Replacement: step 6, image 1 of 2 Gateway NV55C49u RAM Replacement: step 6, image 2 of 2
    • Hold back the plastic that protects the RAM so you can access the clips underneath.
    • Gently push the holding clips outwards. The RAM will angle itself upwards.
    • Gently remove the RAM from the laptop
    • Make sure not to touch any part of the RAM except the sides.
    • When reassembling, insert the RAM into the connector, and then push it down until the clips lock it into place
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 272
