Gateway P-7805u Hard Drive Replacement
  1. Gateway P-7805u Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Unscrew all .5mm screws from the back rectangular panel. Use a J0 screwdriver.
    • Screws will not come out all the way out. Simply unscrew until they do not come out any further.
  2. Gateway P-7805u Hard Drive Replacement: step 2, image 1 of 2 Gateway P-7805u Hard Drive Replacement: step 2, image 2 of 2
    • Firmly press with your hand on the silver surface and pull back, dislodging the hard drive from its port.
  3. Gateway P-7805u Hard Drive Replacement: step 3, image 1 of 1
    • Remove the four 1.2mm screws attaching the case to the hard drive. Use the same J0 screwdriver.
  4. Gateway P-7805u Hard Drive Replacement: step 4, image 1 of 1
    • Pull out the old hard drive.
Emily Pendleton
401 Reputation
4 Guides authored
Baylor, Team S8-G6, Johnson Fall 2017 Member of Baylor, Team S8-G6, Johnson Fall 2017
BU-JOHNSON-F17S8G6
2 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 265
