Gateway SA1 Cooling Fan Replacement
  1. Gateway SA1 Cooling Fan Replacement, Battery: step 1, image 1 of 1
    • Move the latch to the right of the battery to unlock.
  2. Gateway SA1 Cooling Fan Replacement: step 2, image 1 of 1
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
  3. Gateway SA1 Cooling Fan Replacement, Cooling Fan: step 3, image 1 of 2 Gateway SA1 Cooling Fan Replacement, Cooling Fan: step 3, image 2 of 2
    • Unscrew the indicated Philips screw.
    • Screw cannot be completely removed from cover.
  4. Gateway SA1 Cooling Fan Replacement: step 4, image 1 of 1
    • Use the spudger to pry open the cover.
    • There will be three tabs on each side except for the side with the screw.
  5. Gateway SA1 Cooling Fan Replacement: step 5, image 1 of 2 Gateway SA1 Cooling Fan Replacement: step 5, image 2 of 2
    • Unscrew the six indicated Philips screws.
    • These screws cannot be completely removed from the cooling fan component.
  6. Gateway SA1 Cooling Fan Replacement: step 6, image 1 of 1
    • Unplug the shown cable attaching the cooling fan to the computer.
  7. Gateway SA1 Cooling Fan Replacement: step 7, image 1 of 1
    • You are now able to remove the cooling fan.
7 other people completed this guide.
Diego Carteno
273 Reputation
7 Guides authored
Cal Poly, Team 24-20, Regan Spring 2010 Member of Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 13,628
