Gateway SA1 Disk Drive Replacement
  1. Gateway SA1 Disk Drive Replacement, Battery: step 1, image 1 of 1
    • Move the latch to the right of the battery to unlock.
  2. Gateway SA1 Disk Drive Replacement: step 2, image 1 of 1
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
  3. Gateway SA1 Disk Drive Replacement, Disk Drive: step 3, image 1 of 1
    • Unscrew the marked 5.9 mm Philips screw.
  4. Gateway SA1 Disk Drive Replacement: step 4, image 1 of 1
    • Use the spudger to pry out the Disk dive.
  5. Gateway SA1 Disk Drive Replacement: step 5, image 1 of 1
    • The disk drive should easily detach and can now be replaced.
Diego Carteno
273 Reputation
7 Guides authored
Cal Poly, Team 24-20, Regan Spring 2010 Member of Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 12
All Time: 3,574
