Gateway SA1 Hard Drive Replacement
  1. Gateway SA1 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Move the latch to the right of the battery to unlock.
  2. Gateway SA1 Hard Drive Replacement: step 2, image 1 of 1
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
  3. Gateway SA1 Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
    • Before you begin, it's recommended that you back up all your computer's information on the original hard drive. Also, verify the laptop is off and all cables are disconnected.
    • Turn the laptop over so the bottom is facing up.
  4. Gateway SA1 Hard Drive Replacement: step 4, image 1 of 2 Gateway SA1 Hard Drive Replacement: step 4, image 2 of 2
    • Loosen the three Philips cover screws that secure the hard drive.
    • These screws cannot be fully removed from the hard drive cover.
    • Use the spudger to lift and to remove the hard drive cover.
  5. Gateway SA1 Hard Drive Replacement: step 5, image 1 of 2 Gateway SA1 Hard Drive Replacement: step 5, image 2 of 2
    • Slide the original hard drive to the left and lift it to remove.
    • Insert the new hard drive.
5 other people completed this guide.
Diego Carteno
273 Reputation
7 Guides authored
Cal Poly, Team 24-20, Regan Spring 2010 Member of Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 23
All Time: 14,213
