Gateway Solo 1200 RAM Replacement
  1. Gateway Solo 1200  RAM Replacement, Battery: step 1, image 1 of 3 Gateway Solo 1200  RAM Replacement, Battery: step 1, image 2 of 3 Gateway Solo 1200  RAM Replacement, Battery: step 1, image 3 of 3
    • Turn off your laptop and disconnect it from AC Adapter before use.
    • Locate the battery latch on the bottom of the laptop.
    • Release the latch by pressing it with your thumb and sliding it to the right.
    • Slide the battery out of its compartment.
    • Discharge your laptop by pushing the power button after removing the battery.
  2. Gateway Solo 1200  RAM Replacement, RAM: step 2, image 1 of 1
    • Locate the RAM compartment on the underside of the laptop near the center.
  3. Gateway Solo 1200  RAM Replacement: step 3, image 1 of 2 Gateway Solo 1200  RAM Replacement: step 3, image 2 of 2
    • Open the RAM compartment by unscrewing the 2 mm screw with a Phillips #0 screwdriver.
    • Once unscrewed, lift off the compartment cover.
  4. Gateway Solo 1200  RAM Replacement: step 4, image 1 of 1
    • Press the silver retention levers on either side of the RAM away from the center of the RAM.
    • The RAM stick will pop up after the retention levers are released.
  5. Gateway Solo 1200  RAM Replacement: step 5, image 1 of 1
    • Pull the RAM stick out of its socket.
5 other people completed this guide.
Addison
3,081 Reputation
17 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 15
All Time: 949
