Gateway Solo 1200 Fan Replacement
  1. Gateway Solo 1200 Fan Replacement, Battery: step 1, image 1 of 3 Gateway Solo 1200 Fan Replacement, Battery: step 1, image 2 of 3 Gateway Solo 1200 Fan Replacement, Battery: step 1, image 3 of 3
    • Turn off your laptop and disconnect it from AC Adapter before use.
    • Locate the battery latch on the bottom of the laptop.
    • Release the latch by pressing it with your thumb and sliding it to the right.
    • Slide the battery out of its compartment.
    • Discharge your laptop by pushing the power button after removing the battery.
  2. Gateway Solo 1200 Fan Replacement, Keyboard and Frame: step 2, image 1 of 2 Gateway Solo 1200 Fan Replacement, Keyboard and Frame: step 2, image 2 of 2
    • Turn the device so the back is facing you.
    • Unscrew the 2 mm screws with a Phillips #0 screwdriver.
    • Unscrewing these back screws partially releases the keyboard.
  3. Gateway Solo 1200 Fan Replacement: step 3, image 1 of 2 Gateway Solo 1200 Fan Replacement: step 3, image 2 of 2
    • Open up the device so the keyboard is visible.
    • Locate the front panel with the power button above the keyboard.
    • Remove the panel by gently pulling on it.
    • The panel should pop out with little force.
  4. Gateway Solo 1200 Fan Replacement: step 4, image 1 of 3 Gateway Solo 1200 Fan Replacement: step 4, image 2 of 3 Gateway Solo 1200 Fan Replacement: step 4, image 3 of 3
    • Gently lift the keyboard panel up.
    • Flip the keyboard panel over to reveal the underside.
    • Gently tug on the ribbon cable at the bottom of the keyboard panel to release the keyboard.
  5. Gateway Solo 1200 Fan Replacement: step 5, image 1 of 3 Gateway Solo 1200 Fan Replacement: step 5, image 2 of 3 Gateway Solo 1200 Fan Replacement: step 5, image 3 of 3
    • Remove both monitor hinge covers at the base of the screen by unscrewing the 2 mm screws with a Phillips #0 screwdriver.
    • Locate the visual output cord on the exposed left hinge connecting the monitor to the laptop.
    • Gently tug on the visual output cord to remove the screen.
  6. Gateway Solo 1200 Fan Replacement: step 6, image 1 of 3 Gateway Solo 1200 Fan Replacement: step 6, image 2 of 3 Gateway Solo 1200 Fan Replacement: step 6, image 3 of 3
    • Once the screen is removed, locate the keyboard frame screws.
    • Unscrew the outer frame and gently pull it away from the device.
    • Gently tug on the trackpad connector underneath the keyboard frame to completely remove it.
  7. Gateway Solo 1200 Fan Replacement, Fan: step 7, image 1 of 3 Gateway Solo 1200 Fan Replacement, Fan: step 7, image 2 of 3 Gateway Solo 1200 Fan Replacement, Fan: step 7, image 3 of 3
    • Locate the heatsink next to the fan.
    • Unscrew the four 2mm screws attaching the heatsink to the device.
    • Lift the heatsink upwards, careful not to disturb other internal components.
  8. Gateway Solo 1200 Fan Replacement: step 8, image 1 of 3 Gateway Solo 1200 Fan Replacement: step 8, image 2 of 3 Gateway Solo 1200 Fan Replacement: step 8, image 3 of 3
    • Unscrew the four screws attaching the fan to the device.
    • Carefully tug the fan's connector from the heat system.
    • The connector is fragile and shouldn't be yanked to avoid damages.
Riki
235 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 14
All Time: 217
