Gateway W350I Display Replacement
  1. Gateway W350I Display Replacement, Battery Access: step 1, image 1 of 1
    • Turn the laptop upside down and position it as shown in the image.
  2. Gateway W350I Display Replacement, Unlocking the Battery: step 2, image 1 of 3 Gateway W350I Display Replacement, Unlocking the Battery: step 2, image 2 of 3 Gateway W350I Display Replacement, Unlocking the Battery: step 2, image 3 of 3
    • Slide the locking switch towards the open lock picture.
    • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
    • Once the laptop is disengaged, completely remove the battery from the laptop.
  3. Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: step 3, image 1 of 2 Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: step 3, image 2 of 2
    • Pry the six black rubber protectors out of the screw holes.
    • Remove all six of the 4mm Phillips #0 screws that were covered by the rubber protectors.
  4. Gateway W350I Display Replacement, Separate Plastic Casing: step 4, image 1 of 2 Gateway W350I Display Replacement, Separate Plastic Casing: step 4, image 2 of 2
    • Separate the plastic screen casing from the laptop lid by inserting a plastic opening tool. Complete this step around the top and along both sides of the screen.
  5. Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: step 5, image 1 of 2 Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: step 5, image 2 of 2
    • Remove the two 4mm Phillips #0 screws located at the top that fasten the screen bracket to the laptop.
  6. Gateway W350I Display Replacement, Remove LCD Screen from Bracket: step 6, image 1 of 1
    • Separate the bracket and the screen from its original position within the lid of the laptop.
    • Remove the four 4mm Phillips #0 screws on the sides of the bracket that hold the LCD screen.
  7. Gateway W350I Display Replacement, Remove Video Cable: step 7, image 1 of 2 Gateway W350I Display Replacement, Remove Video Cable: step 7, image 2 of 2
    • Detach the video cable that is attached to the laptop from the back of the screen.
    • Be careful while removing the video cable as it is very delicate.
  8. Gateway W350I Display Replacement: step 8, image 1 of 2 Gateway W350I Display Replacement: step 8, image 2 of 2
    • Disconnect the camera connector from the circuit board to completely free the screen.
3 other people completed this guide.
Samuel Newton
296 Reputation
1 Guide authored
USF Tampa, Team 4-1, Brown Fall 2014 Member of USF Tampa, Team 4-1, Brown Fall 2014
USFT-BROWN-F14S4G1
3 Members
10 Guides authored
One Comment
It was very easy to follow.
Very friendly guide.
Stephan Williams - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 18
All Time: 1,290
