Gateway W350I Heatsink Fan Replacement
  1. Gateway W350I Heatsink Fan Replacement, Battery Access: step 1, image 1 of 1
    • Turn the laptop upside down and position it as shown in the image.
  2. Gateway W350I Heatsink Fan Replacement, Unlocking the Battery: step 2, image 1 of 3 Gateway W350I Heatsink Fan Replacement, Unlocking the Battery: step 2, image 2 of 3 Gateway W350I Heatsink Fan Replacement, Unlocking the Battery: step 2, image 3 of 3
    • Slide the locking switch towards the open lock picture.
    • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
    • Once the laptop is disengaged, completely remove the battery from the laptop.
  3. Gateway W350I Heatsink Fan Replacement, Remove Bottom Cover: step 3, image 1 of 3 Gateway W350I Heatsink Fan Replacement, Remove Bottom Cover: step 3, image 2 of 3 Gateway W350I Heatsink Fan Replacement, Remove Bottom Cover: step 3, image 3 of 3
    • Remove the single 3mm Phillips #0 screw holding on the plastic cover.
    • Use a plastic opening tool to gently pry off the plastic cover.
  4. Gateway W350I Heatsink Fan Replacement, Remove Srews & Tape: step 4, image 1 of 3 Gateway W350I Heatsink Fan Replacement, Remove Srews & Tape: step 4, image 2 of 3 Gateway W350I Heatsink Fan Replacement, Remove Srews & Tape: step 4, image 3 of 3
    • Remove all four 3mm Phillips #0 screws holding in the fan.
    • Remove the tape from the top of the fan
  5. Gateway W350I Heatsink Fan Replacement, Removing Heat-Sink Fan: step 5, image 1 of 3 Gateway W350I Heatsink Fan Replacement, Removing Heat-Sink Fan: step 5, image 2 of 3 Gateway W350I Heatsink Fan Replacement, Removing Heat-Sink Fan: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Gently remove the fan from the metal housing.
    • Disconnect the cable with tweezers.
Aaron Austin
249 Reputation
2 Guides authored
USF Tampa, Team 4-1, Brown Fall 2014 Member of USF Tampa, Team 4-1, Brown Fall 2014
USFT-BROWN-F14S4G1
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 1,035
