Geardup RC Ford Mustang GT Remote Circuit Board Replacement
  1. Geardup RC Ford Mustang GT Remote Circuit Board Replacement, Lower Remote Control: step 1, image 1 of 3 Geardup RC Ford Mustang GT Remote Circuit Board Replacement, Lower Remote Control: step 1, image 2 of 3 Geardup RC Ford Mustang GT Remote Circuit Board Replacement, Lower Remote Control: step 1, image 3 of 3
    • Remove the 5mm Phillips #0 screw from the remote control.
    • Using the tab, lift the battery cover from the remote control to expose the battery.
  2. Geardup RC Ford Mustang GT Remote Circuit Board Replacement, Remote Circuit Board: step 2, image 1 of 2 Geardup RC Ford Mustang GT Remote Circuit Board Replacement, Remote Circuit Board: step 2, image 2 of 2
    • Unscrew the six 5mm Phillips #0 screws on the back of the remote
    • Separate the back of the remote from the front panel.
    • During re-assembly, make sure the plastic button covers on the front panel align with the buttons on the back panel. If they do not, the buttons may be forced into an always "pressed" state.
  3. Geardup RC Ford Mustang GT Remote Circuit Board Replacement: step 3, image 1 of 1
    • Remove the two left and right buttons from their insets in the controller.
  4. Geardup RC Ford Mustang GT Remote Circuit Board Replacement: step 4, image 1 of 1
    • Remove the 5mm Phillips #0 screw that connects the antennae to the circuit board.
  5. Geardup RC Ford Mustang GT Remote Circuit Board Replacement: step 5, image 1 of 1
    • Unscrew 5mm Phillips #0 screw located at the bottom of the board in the center.
    • Remove the circuit board from the casing.
  6. Geardup RC Ford Mustang GT Remote Circuit Board Replacement: step 6, image 1 of 1
    • Make note of where each wire connects to the circuit board for re-assembly as they will be removed in the next step.
    • Using the copper solder wick, remove the solder connecting the nine wires to the circuit board.
7 other people completed this guide.
Jake Stone
611 Reputation
4 Guides authored
Cal Poly, Team 8-38, Amido Winter 2015 Member of Cal Poly, Team 8-38, Amido Winter 2015
CPSU-AMIDO-W15S8G38
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 6,058
