Geberit toilet flush (old model) replacement of the seal
  1. Geberit toilet flush (old model) replacement of the seal, Remove cover (flush-mounted model): step 1, image 1 of 3 Geberit toilet flush (old model) replacement of the seal, Remove cover (flush-mounted model): step 1, image 2 of 3 Geberit toilet flush (old model) replacement of the seal, Remove cover (flush-mounted model): step 1, image 3 of 3
    • Lift pressure plate from bottom to top, then remove
    • first unscrew the outer frame
    • then the inner cover. Carefully pull away to the front.
  2. Geberit toilet flush (old model) replacement of the seal, Surface model: step 2, image 1 of 1
    • Grab left and right and pull up quite vigorously.
  3. Geberit toilet flush (old model) replacement of the seal: step 3, image 1 of 1
    • Be sure to turn off the water inlet, e.g. at this corner tap.
  4. Geberit toilet flush (old model) replacement of the seal, The valve: step 4, image 1 of 2 Geberit toilet flush (old model) replacement of the seal, The valve: step 4, image 2 of 2
    • The filling valve. Photo 1 with the surface box.
    • Photo 2 shows the valve in the flush-mounted box.
  5. Geberit toilet flush (old model) replacement of the seal, Disconnect water inlet: step 5, image 1 of 1
    • With a water pump pliers, you loosen the union nut on the valve. So it is separated from the water inlet.
    • Remove the hose slowly so that no part falls out.
  6. Geberit toilet flush (old model) replacement of the seal, Lift out the valve: step 6, image 1 of 1
    • With the surface-mounted box you can simply push the valve upwards.
    • With the flush-mounted box, lift the valve upwards and set it aside. then push on the upper part until the float releases.
    • Now you can lift out the parts.
  7. Geberit toilet flush (old model) replacement of the seal: step 7, image 1 of 1
    • Here you can see the parts of the valve. The seal is the red dot!
  8. Geberit toilet flush (old model) replacement of the seal: step 8, image 1 of 2 Geberit toilet flush (old model) replacement of the seal: step 8, image 2 of 2
    • Now the seal has to be removed and replaced. It is sometimes difficult to find out. Try a small screwdriver.
    • Figure 2 shows a defective seal (here black). Clearly a ring is pressed into it.
    • If the seal is still elastic, you can just flip it over. A new seal is really not expensive.
  9. Geberit toilet flush (old model) replacement of the seal: step 9, image 1 of 1
    • When reassembling you have to make sure that the release lever engages correctly again. Use a screwdriver if necessary.
Repeat the steps in reverse order to reassemble your device.
4 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
210,196 Reputation
255 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
26 Members
1,185 Guides authored
3 Comments
I don’t like Geberit toilet. My all time favorite flushing toilet is American standard https://bestflushingtoilet.org/american-.... Really, I like this brand flushing technology.
zukond - Reply
That’s a great effort to share information about the Geberit toilet, but I think most people do not use these toilets. Here https://lueliving.com/ is a list of some best toilest. I’m sure that will be helpful.
jana - Reply
In Europe, Geberit is very popular, and it is one of the few brands that provides parts/upgrades for older models (even going back to 1964, when they started).
Tom Verhoeff - Reply
Past 24 Hours: 109
Past 7 Days: 597
Past 30 Days: 2,603
All Time: 61,849
