Introduction
If your George Foreman GR-20 (model GR20WHT) has ceased to function properly, then disassembling it is the first step towards diagnosing and fixing your GR-20. Use this guide to walk you through step by step how to completely disassemble your George Foreman GR-20. Before beginning the disassembly process, check to make sure the device is disconnected from any external power source and cool to the touch. Following the necessary safety precautions is important when disassembling. Follow the steps in reverse order for reassembly of your George Foreman GR-20.
Open the grill and remove the two Phillips #2 screws from the top lid.
2 Comments
Needed to disassemble the grill to clean it. The detailed steps, with excellent photos, made the process simple. THANK YOU!!!
