Giant Reign 2 Front Wheel Replacement
  1. Giant Reign 2 Front Wheel Replacement, Hex Screws: step 1, image 1 of 1
    • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
  2. Giant Reign 2 Front Wheel Replacement, Axle Screw: step 2, image 1 of 2 Giant Reign 2 Front Wheel Replacement, Axle Screw: step 2, image 2 of 2
    • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
    • Push the axle screw to reveal the axle rod on the other side.
  3. Giant Reign 2 Front Wheel Replacement: step 3, image 1 of 1
    • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
    • Hold the wheel when pulling out the axle rod so that the bike does not fall.
  4. Giant Reign 2 Front Wheel Replacement, Front Wheel: step 4, image 1 of 1
    • Pull the wheel from the fork.
2 other people completed this guide.
Andrew Krasts
302 Reputation
2 Guides authored
Cal Poly, Team 9-14, Amido Fall 2012 Member of Cal Poly, Team 9-14, Amido Fall 2012
CPSU-AMIDO-F12S9G14
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 97
All Time: 14,248
