Giant Reign 2 Headset Replacement
  1. Giant Reign 2 Headset Replacement, Hex Screws: step 1, image 1 of 1
    • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
  2. Giant Reign 2 Headset Replacement, Axle Screw: step 2, image 1 of 2 Giant Reign 2 Headset Replacement, Axle Screw: step 2, image 2 of 2
    • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
    • Push the axle screw to reveal the axle rod on the other side.
  3. Giant Reign 2 Headset Replacement: step 3, image 1 of 1
    • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
    • Hold the wheel when pulling out the axle rod so that the bike does not fall.
  4. Giant Reign 2 Headset Replacement, Front Wheel: step 4, image 1 of 1
    • Pull the wheel from the fork.
  5. Giant Reign 2 Headset Replacement, Headset: step 5, image 1 of 2 Giant Reign 2 Headset Replacement, Headset: step 5, image 2 of 2
    • Using the 8mm Allen wrench, unscrew 2 (32mm) screws to release the brake calipers from the fork.
    • If necessary use wire cutters to release zip ties attaching cables to the forks.
  6. Giant Reign 2 Headset Replacement: step 6, image 1 of 3 Giant Reign 2 Headset Replacement: step 6, image 2 of 3 Giant Reign 2 Headset Replacement: step 6, image 3 of 3
    • Using the 8mm Allen wrench, unscrew the 30mm head screw located on top of the steam.
    • Using the 4mm Allen wrench, loosen the side screw on both sides.
    • Lift off the handlebar.
    • Hang the handlebar gently from the cables. Do not pull the cables as you may damage the brake/derailleur lines.
  7. Giant Reign 2 Headset Replacement: step 7, image 1 of 3 Giant Reign 2 Headset Replacement: step 7, image 2 of 3 Giant Reign 2 Headset Replacement: step 7, image 3 of 3
    • Slide off the spacers.
    • Lift off the seal.
  8. Giant Reign 2 Headset Replacement: step 8, image 1 of 1
    • Slide the fork out of the casing.
  9. Giant Reign 2 Headset Replacement: step 9, image 1 of 1
    • Using your fingers, pry the bearings from the top and bottom of the headset.
  10. Giant Reign 2 Headset Replacement: step 10, image 1 of 1
    • Apply WD-40 to both ends of the headset and bearings.
    • Dry headset and bearings with paper towels.
    • Repeat as necessary until clean.
  11. Giant Reign 2 Headset Replacement: step 11, image 1 of 2 Giant Reign 2 Headset Replacement: step 11, image 2 of 2
    • Using your finger, apply all-purpose lube to the bearings and each end of the headset.
    • Insert the bearings into the headset with the beveled side facing into the headset.
Sterling Grande
148 Reputation
4 Guides authored
Cal Poly, Team 9-14, Amido Fall 2012 Member of Cal Poly, Team 9-14, Amido Fall 2012
CPSU-AMIDO-F12S9G14
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 4,310
