Giant Reign 2 Rear Shock Replacement
  1. Giant Reign 2 Rear Shock Replacement, Rear Shock: step 1, image 1 of 1
    • Orient the bike upside down.
  2. Giant Reign 2 Rear Shock Replacement: step 2, image 1 of 1
    • Remove the 10mm screw and take the bash guard off of the frame.
  3. Giant Reign 2 Rear Shock Replacement: step 3, image 1 of 1
    • Remove the 65mm screw that connects the bottom of the shock to the frame.
    • Use a wrench to hold the other side.
  4. Giant Reign 2 Rear Shock Replacement: step 4, image 1 of 1
    • Remove the 40mm screw that connects the shock to the link arm of the suspension.
  5. Giant Reign 2 Rear Shock Replacement: step 5, image 1 of 2 Giant Reign 2 Rear Shock Replacement: step 5, image 2 of 2
    • Push the shock out of the brackets mounting it to the frame and suspension arm.
    • This may require some force and slight wiggling from side to side.
Andrew Krasts
302 Reputation
2 Guides authored
Cal Poly, Team 9-14, Amido Fall 2012 Member of Cal Poly, Team 9-14, Amido Fall 2012
CPSU-AMIDO-F12S9G14
4 Members
10 Guides authored
One Comment
Which valve stem is the one to put air into the shock there's one on the bottom one on top and adjustment knob right next to the top one
Ron Hobson - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 27
All Time: 4,932
