Giant Reign 2 Tube Replacement
  1. Giant Reign 2 Tube Replacement, Hex Screws: step 1, image 1 of 1
    • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
  2. Giant Reign 2 Tube Replacement, Axle Screw: step 2, image 1 of 2 Giant Reign 2 Tube Replacement, Axle Screw: step 2, image 2 of 2
    • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
    • Push the axle screw to reveal the axle rod on the other side.
  3. Giant Reign 2 Tube Replacement: step 3, image 1 of 1
    • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
    • Hold the wheel when pulling out the axle rod so that the bike does not fall.
  4. Giant Reign 2 Tube Replacement, Front Wheel: step 4, image 1 of 1
    • Pull the wheel from the fork.
  5. Giant Reign 2 Tube Replacement, Tube: step 5, image 1 of 1
    • Look at your tire and determine the correct tube size by locating the number (formated ## x #.##) on the wall of the tire.
    • Bike tubes come with one of two standard valve types: presta and schrader. These guides show the installation of a tube with a presta valve.
  6. Giant Reign 2 Tube Replacement: step 6, image 1 of 3 Giant Reign 2 Tube Replacement: step 6, image 2 of 3 Giant Reign 2 Tube Replacement: step 6, image 3 of 3
    • Unscrew the cap covering the valve.
    • Remove the spacer that holds the valve in place against the rim of the wheel.
    • Open the valve by turning the nut and pressing the valve in to release air pressure from the tube.
  7. Giant Reign 2 Tube Replacement: step 7, image 1 of 3 Giant Reign 2 Tube Replacement: step 7, image 2 of 3 Giant Reign 2 Tube Replacement: step 7, image 3 of 3
    • Slide the tire lever between the tire and the rim.
    • Push down on the tire lever until the edge of the tire is higher than the edge of the rim.
    • Insert a second tire lever adjacent to the first.
    • Slowly work one tire lever around the rim until the whole tire is loose.
  8. Giant Reign 2 Tube Replacement: step 8, image 1 of 2 Giant Reign 2 Tube Replacement: step 8, image 2 of 2
    • Press the valve through the rim of the wheel.
    • Remove the tube from the tire.
  9. Giant Reign 2 Tube Replacement: step 9, image 1 of 1
    • Partially inflate the tube.
  10. Giant Reign 2 Tube Replacement: step 10, image 1 of 2 Giant Reign 2 Tube Replacement: step 10, image 2 of 2
    • Push the valve through the rim.
    • Push the tube into the tire all the way around the rim of the wheel.
  11. Giant Reign 2 Tube Replacement: step 11, image 1 of 1
    • Push the bead of the tire back into place around the rim.
    • Make sure not to pinch the tube between the bead of the tire and the rim. Failure to do so may cause a pinch flat.
  12. Giant Reign 2 Tube Replacement: step 12, image 1 of 1
    • Inflate the tube to the desired air pressure.
    • A suggested range of air pressure is located on the wall of the tire (formatted ##-##psi).
  13. Giant Reign 2 Tube Replacement: step 13, image 1 of 2 Giant Reign 2 Tube Replacement: step 13, image 2 of 2
    • Close the valve and replace the cap.
Finish Line
Sterling Grande
148 Reputation
4 Guides authored
Cal Poly, Team 9-14, Amido Fall 2012 Member of Cal Poly, Team 9-14, Amido Fall 2012
CPSU-AMIDO-F12S9G14
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 20
All Time: 3,127
