Giant Talon 29er Chainring Replacement
  1. Giant Talon 29er Chainring Replacement, Chainring: step 1, image 1 of 3 Giant Talon 29er Chainring Replacement, Chainring: step 1, image 2 of 3 Giant Talon 29er Chainring Replacement, Chainring: step 1, image 3 of 3
    • Push the chain tensioner towards the front of the bicycle to release the tension on the chain.
    • Unroute the chain from the chainrings.
  2. Giant Talon 29er Chainring Replacement: step 2, image 1 of 1
    • Remove the 8 mm Hex screw from the crank arm.
  3. Giant Talon 29er Chainring Replacement: step 3, image 1 of 1
    • Remove the crank arm and chainrings by pulling the crank arm away from the bicycle frame.
  4. Giant Talon 29er Chainring Replacement: step 4, image 1 of 1
    • Remove the four 5 mm Hex screws that mount the crank arm to the chainrings.
  5. Giant Talon 29er Chainring Replacement: step 5, image 1 of 3 Giant Talon 29er Chainring Replacement: step 5, image 2 of 3 Giant Talon 29er Chainring Replacement: step 5, image 3 of 3
    • Rotate the largest chainring 45 degrees in either direction.
    • Remove the crank arm from the chainrings.
Reassemble your bicycle with the new chainrings by following these instructions in reverse order.
Ben Frisbie
209 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 25
All Time: 3,873
