Gigabyte P34G Hard Drive Replacement
  1. Gigabyte P34G Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Remove all 15 marked screws on the underside of the laptop using a #0 screwdriver.
    • There are three different sized screws.
    • 1x 9.8mm Screw
    • 8x 5.6mm Screws
    • 6x 5.0mm Screws
    • Divide the screws by size and save them in a safe space for reassembly later.
  2. Gigabyte P34G Hard Drive Replacement: step 2, image 1 of 2 Gigabyte P34G Hard Drive Replacement: step 2, image 2 of 2
    • Carefully peel back the two pieces of black tape holding down the cord.
    • Pull the marked tab straight up away from the board to disconnect the hard drive from the board.
  3. Gigabyte P34G Hard Drive Replacement: step 3, image 1 of 1
    • Carefully lift the hard drive for removal.
yeunghayden
841 Reputation
6 Guides authored
Cal Poly, Team 8-1, Regan Spring 2015 Member of Cal Poly, Team 8-1, Regan Spring 2015
CPSU-REGAN-S15S8G1
5 Members
12 Guides authored
1 Guide Comment
Hi.
Can you please show me how to remove the back cover on the gigabyte sabre 17 laptop?
Need to change the hdd but cannot open the back.
Thank you.
Rizwan - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 3,720
