Gigabyte P34G RAM Replacement
  1. Gigabyte P34G RAM Replacement, RAM: step 1, image 1 of 1
    • Unscrew the single 9.8mm screw on the underside of the laptop using a #0 screwdriver.
    • Set the screw and cover plate in a safe space for reassembly later.
  2. Gigabyte P34G RAM Replacement: step 2, image 1 of 1
    • Pull the two marked tabs to the sides to release the RAM.
  3. Gigabyte P34G RAM Replacement: step 3, image 1 of 1
    • Carefully remove the existing RAM by pulling away from the connector and set it aside.
    • After replacement, remember to re-lock the two white pins to secure the new RAM.
2 other people completed this guide.
yeunghayden
841 Reputation
6 Guides authored
Cal Poly, Team 8-1, Regan Spring 2015 Member of Cal Poly, Team 8-1, Regan Spring 2015
CPSU-REGAN-S15S8G1
5 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 1,181
