Gipo H369e Screen Replacement
  1. Gipo H369e Screen Replacement, Screen: step 1, image 1 of 2 Gipo H369e Screen Replacement, Screen: step 1, image 2 of 2
    • Insert your thumb into the groove on the back lefthand corner of the phone to unsnap the back cover.
  2. Gipo H369e Screen Replacement: step 2, image 1 of 1
    • Remove the battery from the back of the phone.
  3. Gipo H369e Screen Replacement: step 3, image 1 of 2 Gipo H369e Screen Replacement: step 3, image 2 of 2
    • Unscrew the 6 screws on the back of the phone using the Philips Head 000 screwdriver.
    • You can use the back cover as a tray to hold the loose screws.
  4. Gipo H369e Screen Replacement: step 4, image 1 of 2 Gipo H369e Screen Replacement: step 4, image 2 of 2
    • Use the plastic opening tool to pry the front of the phone away from the back of the phone.
  5. Gipo H369e Screen Replacement: step 5, image 1 of 1
    • Once the front and back of the phone are separated, push the keypad out of the front portion of the phone.
  6. Gipo H369e Screen Replacement: step 6, image 1 of 3 Gipo H369e Screen Replacement: step 6, image 2 of 3 Gipo H369e Screen Replacement: step 6, image 3 of 3
    • Use the needle nose pliers to pull the screen away from the front of the disassembled phone. Replace it with your new screen.
6 other people completed this guide.
Janelle Norris
173 Reputation
2 Guides authored
Ohio State, Team 1-4, Garvin Fall 2015 Member of Ohio State, Team 1-4, Garvin Fall 2015
OSU-GARVIN-F15S1G4
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 13
All Time: 545
