Globe Light Bulb Replacement
  1. Globe Light Bulb Replacement, light bulb: step 1, image 1 of 2 Globe Light Bulb Replacement, light bulb: step 1, image 2 of 2
    • With a plastic meridian like this one, you need to raise the meridian slightly from the North Pole. Use the plastic ring on the north pole to gently press the globe down and pull up the meridian so you lift the little pin,which holdes the globe.
  2. Globe Light Bulb Replacement: step 2, image 1 of 1
    • Now you can slowly turn the globe to the side and lift it from the socket at the south pole.
    • Be careful not to scratch the globe with the meridian.
  3. Globe Light Bulb Replacement: step 3, image 1 of 1
    • You can replace the bulb now. Screw the new bulb into the socket.
    • Please make sure that you are using an equivalent bulb.
  4. Globe Light Bulb Replacement: step 4, image 1 of 1
    • Finally install the globe again by placing it back on the south pole and fixing the meridian on to the north pole.
  5. Globe Light Bulb Replacement: step 5, image 1 of 1
    • Your globe is now glowing bright again.
Finish Line
Athina Pilitsidou
171 Reputation
1 Guide authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 41
Past 30 Days: 136
All Time: 7,367
