GoPro Hero Battery Replacement
  1. GoPro Hero Battery Replacement, Battery: step 1, image 1 of 1
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero Battery Replacement: step 2, image 1 of 1
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero Battery Replacement: step 3, image 1 of 1
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
    • Use a plastic spudger to pry the battery off from the white plastic piece underneath.
    • The battery is glued to the plastic so some force might be necessary.
    • Be careful not to damage the battery to avoid releasing dangerous chemicals.
  4. GoPro Hero Battery Replacement: step 4, image 1 of 1
    • Remove the battery from the GoPro.
28 other people completed this guide.
River Drake
1,047 Reputation
5 Guides authored
Cal Poly, Team 12-2, Lancaster Spring 2015 Member of Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Members
18 Guides authored
20 Guide Comments
The tutorial is excellent, even with a link to the tools needed, but no link to battery sale.
Could you please include this?
juliomap - Reply
Very good tutorial thank you. But I can also find no place to buy a new battery... But here is a petition to make Gopro sell spare parts: https://www.change.org/p/gopro-support-o...
maire - Reply
I followed these steps and inadvertently pulled not only the battery plug but its adapter (housing) at the same time. Now I can't plug the battery back in because there's no place to plug it! Contacting GoPro they stressed that the battery is not intended for removal.
erikwikstrom - Reply
Awesome! Could you also show us how to put in a new battery, how do i prep my battery? What type of a battery can i use ? Thanks a lot !!
John misquita - Reply
now add go pro to rice for a day and pray.
chadd23 - Reply
Past 24 Hours: 3
Past 7 Days: 65
Past 30 Days: 231
All Time: 82,083
