GoPro Hero Motherboard Replacement
  1. GoPro Hero Motherboard Replacement, Casing: step 1, image 1 of 1
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero Motherboard Replacement: step 2, image 1 of 1
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero Motherboard Replacement: step 3, image 1 of 1
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero Motherboard Replacement: step 4, image 1 of 1
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero Motherboard Replacement: step 5, image 1 of 1
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero Motherboard Replacement: step 6, image 1 of 1
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero Motherboard Replacement, Motherboard: step 7, image 1 of 2 GoPro Hero Motherboard Replacement, Motherboard: step 7, image 2 of 2
    • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
    • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
  8. GoPro Hero Motherboard Replacement: step 8, image 1 of 2 GoPro Hero Motherboard Replacement: step 8, image 2 of 2
    • Separate the white plastic piece from the motherboard.
4 other people completed this guide.
Zoe Tuggle
179 Reputation
1 Guide authored
Cal Poly, Team 12-2, Lancaster Spring 2015 Member of Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Members
18 Guides authored
2 Comments
So after doing all theses steps did it resolve the problem
Anita - Reply
Thanks so much I really needed this guide.
Thanks, Sam
Sam Liam Matthews - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 54
All Time: 10,243
