GoPro Hero3+ Black Edition Front Face Plate Replacement
  1. GoPro Hero3+ Black Edition Front Face Plate Replacement, Front Face Plate: step 1, image 1 of 2 GoPro Hero3+ Black Edition Front Face Plate Replacement, Front Face Plate: step 1, image 2 of 2
    • Using a plastic opening tool, pry the gray, front face plate until it can be removed from the housing.
    • To avoid breaking or weakening the tabs on the face plate which hold it in place, alternate the sides from which you pry and check each tab before separating the plate from the body.
To reassemble your device, press face plate back on with hands.
Nathan Braham
110 Reputation
1 Guide authored
Cal Poly, Team 6-15, Maness Spring 2015 Member of Cal Poly, Team 6-15, Maness Spring 2015
CPSU-MANESS-S15S6G15
4 Members
13 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,785
