GoPro Hero4 Black LCD Screen Replacement
Jeffrey Goethe
Jeffrey Goethe and 6 other contributors
Last updated on May 7, 2024
15 - 30 minutes
Moderate
Parts
Tools
Show more…
  1. GoPro Hero4 Black LCD Screen Replacement, Midframe Housing: step 1, image 1 of 3 GoPro Hero4 Black LCD Screen Replacement, Midframe Housing: step 1, image 2 of 3 GoPro Hero4 Black LCD Screen Replacement, Midframe Housing: step 1, image 3 of 3
    Tool used on this step:
    • Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
    • Use the tweezers to lift the faceplate from the rest of the device.
    • The power button on the front of the GoPro may pop off. Ensure to align it properly during reassembly.
  2. GoPro Hero4 Black LCD Screen Replacement: step 2, image 1 of 2 GoPro Hero4 Black LCD Screen Replacement: step 2, image 2 of 2
    • Using a #00 Phillips head screwdriver, remove the following screws:
    • One 4.6 mm screw
    • Three 8.2 mm screws
    • Two 6.1 mm screws
    Any more detailed specs on these screws available? Need to but a replacement set, where to buy? How can I find them, size of the head, and the depth etc! Thanks!!
    bredekorsmo - Reply
    Please note the 4.6 mm screw goes aver the battery door not next to the screen.
    Peter Murphy - Reply
    +1 on the 4.6mm screw being bottom left not top left
    Piers Goodhew -
    ´+1, broke my shell because of this.
    Sara Väinölä -
    There is absolutely no need to remove those 2 screws under the lens… -.-
    Krzysztof Gallus - Reply
  3. GoPro Hero4 Black LCD Screen Replacement: step 3, image 1 of 2 GoPro Hero4 Black LCD Screen Replacement: step 3, image 2 of 2
    • Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
  4. GoPro Hero4 Black LCD Screen Replacement: step 4, image 1 of 3 GoPro Hero4 Black LCD Screen Replacement: step 4, image 2 of 3 GoPro Hero4 Black LCD Screen Replacement: step 4, image 3 of 3
    • Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection.
    • Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard.
    • The clip must be pulled up and away from the motherboard. Attempting to slide it out will damage the clip.
    • During reassembly, remove the black tape on the ribbon cable, turn the camera upside down so you can see the port, and reinsert the cable with tweezers. It's a lot easier!
    Removing the tiny gold ribbon strip and the wires from the right hand side as shown in the image is an unnecessary step to change out the lens. In fact it is recommendable to NOT remove these, especially the gold ribbon strip that is shown in the red box. It is very difficult to get this ZIF cable back in place once it has been removed. Simply open the camera carefully so as not to pull on this cable and the wires and proceed with the other steps.
    Greg Ryder - Reply
    I agree that the 2 cables shown above do NOT need to be removed in order to replace the image sensor. Just keep the internal assembly (circuit boards) close to the black housing and at a 90 degree angle. Don’t put any strain on the cables though! You can still access the 4 screws holding the sensor board in place as well as pull up the connector attaching the sensor to the mainboard. You’ll save a lot of time (and headache) by leaving those cables attached.
    Mark Shelton - Reply
    If you are having trouble connecting the Ribbon cable in particular, use tape to hold buttons in place, remove battery housing & connect the cables up to the battery housing. Then carefully reinsert the battery housing, lay the motherboard down on the casing slightly overhanging the socket end to get to the screw holes.
    Oh my god ! this ribbon strip is the devil ! I turn mad !!!!!!!
    kreypo - Reply
    those ribbon-ports have a lever to release and secure ribbon. DO NOT PULL directly nor insert ribbons without pulling levers up. once they are on right place, push levers down again (one for each ribbon)
    Carlos Ponce - Reply
    I failed on reinserting the ribbon cable here. The “ZIF” port under the LCD was seemingly glued shut, and I ended up damaging the cable trying to reinsert it. I recommend trying one of the approaches above, including leaving these cables connected or removing the battery module from the case to make this step easier.
    Sparr Risher - Reply
  5. GoPro Hero4 Black LCD Screen Replacement, LCD Screen: step 5, image 1 of 2 GoPro Hero4 Black LCD Screen Replacement, LCD Screen: step 5, image 2 of 2
    • Open the clip that is located on the motherboard
    • Use a pair of tweezers to pull the ribbon from the clip
  6. GoPro Hero4 Black LCD Screen Replacement: step 6, image 1 of 3 GoPro Hero4 Black LCD Screen Replacement: step 6, image 2 of 3 GoPro Hero4 Black LCD Screen Replacement: step 6, image 3 of 3
    • Before you start this step flip the section holding the LCD screen over
    • Place the iOpener on the LCD screen cover to release the glue
    • Lift the covering of the LCD screen cover off with a pair of tweezers
  7. GoPro Hero4 Black LCD Screen Replacement: step 7, image 1 of 2 GoPro Hero4 Black LCD Screen Replacement: step 7, image 2 of 2
    • Use a pair of tweezers to lift the ribbon through the opening and lift all the way up to the LCD screen
    • A section of our LCD screen ribbon was broken so it is not visible from the image.
  8. GoPro Hero4 Black LCD Screen Replacement: step 8, image 1 of 2 GoPro Hero4 Black LCD Screen Replacement: step 8, image 2 of 2
    • Place the iOpener on the LCD screen to remove the glue
    • Use a pair of tweezers to left the LCD screen off the device
5 other people completed this guide.
Jeffrey Goethe
674 Reputation
3 Guides authored
USF Tampa, Team S2-G1, Sullivan Spring 2017 Member of USF Tampa, Team S2-G1, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G1
4 Members
12 Guides authored
4 Comments
Bonjour , est ce que je peux installer un écran LCD sur une hero 4 silver ( sans écran LCD d'origine ) . Je dispose d'une hero 4 black LCD HS . Merci de vos réponses. Sébastien
Coolsaet - Reply
No, ce n'est malheureusement pas possible.
Der Zurechtweiser -
You got the screw locations on the front wrong. Bottom left is the shortest screw, where the battery compartment is. If you try putting one of the longer screws through their it'll bust into the battery compartment. Ask me how I know. And that's the one reason why I came to this, the one thing I couldn't remember.
fat_toni987 - Reply
My GoPro Hero4 Black Button Won't Click After Screen Replacement
I did the GoPro Hero4 Black LCD Screen Replacement. The problem is, I don't get the button to click with the Midframe Housing on. Pressing the naked button works, but the mode plastic button doesn't work when placed above it, there is no clicking sound and no function.
Should I put a placeholder somewhere?
What could be the solution?
Der Zurechtweiser - Reply
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 55
All Time: 7,796
