GoPro Hero4 Black Midframe Housing Replacement
Thomas Sullivan
Thomas Sullivan and 6 other contributors
Last updated on May 7, 2024
15 - 30 minutes
Moderate
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
Tools
Show more…
  1. GoPro Hero4 Black Midframe Housing Replacement, Midframe Housing: step 1, image 1 of 3 GoPro Hero4 Black Midframe Housing Replacement, Midframe Housing: step 1, image 2 of 3 GoPro Hero4 Black Midframe Housing Replacement, Midframe Housing: step 1, image 3 of 3
    Tool used on this step:
    • Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
    • Use the tweezers to lift the faceplate from the rest of the device.
    • The power button on the front of the GoPro may pop off. Ensure to align it properly during reassembly.
  2. GoPro Hero4 Black Midframe Housing Replacement: step 2, image 1 of 2 GoPro Hero4 Black Midframe Housing Replacement: step 2, image 2 of 2
    • Using a #00 Phillips head screwdriver, remove the following screws:
    • One 4.6 mm screw
    • Three 8.2 mm screws
    • Two 6.1 mm screws
  3. GoPro Hero4 Black Midframe Housing Replacement: step 3, image 1 of 2 GoPro Hero4 Black Midframe Housing Replacement: step 3, image 2 of 2
    • Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
  4. GoPro Hero4 Black Midframe Housing Replacement: step 4, image 1 of 3 GoPro Hero4 Black Midframe Housing Replacement: step 4, image 2 of 3 GoPro Hero4 Black Midframe Housing Replacement: step 4, image 3 of 3
    • Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection.
    • Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard.
    • The clip must be pulled up and away from the motherboard. Attempting to slide it out will damage the clip.
    • During reassembly, remove the black tape on the ribbon cable, turn the camera upside down so you can see the port, and reinsert the cable with tweezers. It's a lot easier!
Thomas Sullivan
595 Reputation
3 Guides authored
USF Tampa, Team S2-G1, Sullivan Spring 2017 Member of USF Tampa, Team S2-G1, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G1
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 7
All Time: 72
