GoPro Karma Propeller Replacement
  1. GoPro Karma Propeller Replacement, Battery: step 1, image 1 of 1
    • Hook your fingers on the tab and pull out the battery.
  2. GoPro Karma Propeller Replacement, Stabilizer: step 2, image 1 of 3 GoPro Karma Propeller Replacement, Stabilizer: step 2, image 2 of 3 GoPro Karma Propeller Replacement, Stabilizer: step 2, image 3 of 3
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  3. GoPro Karma Propeller Replacement: step 3, image 1 of 1
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
  4. GoPro Karma Propeller Replacement, Propeller: step 4, image 1 of 3 GoPro Karma Propeller Replacement, Propeller: step 4, image 2 of 3 GoPro Karma Propeller Replacement, Propeller: step 4, image 3 of 3
    • Extend the arms and set the drone face up.
    • The front right and back left propellers unscrew clockwise.
    • The front left and back right propellers unscrew counterclockwise.
  5. GoPro Karma Propeller Replacement: step 5, image 1 of 2 GoPro Karma Propeller Replacement: step 5, image 2 of 2
    • Place the GoPro Karma wrench on the motor.
    • Hold the motor in place with the wrench and unscrew the propeller in the indicated direction.
Jay Ingram
334 Reputation
3 Guides authored
Cal Poly, Team S25-G14, Maness Spring 2018 Member of Cal Poly, Team S25-G14, Maness Spring 2018
CPSU-MANESS-S18S25G14
4 Members
6 Guides authored
2 Guide Comments
You got it the wrong way around, to take them off you need to do the exact opposite to what you say.
michael.woelk - Reply
hi, i am trying to fix my Karma. I have to remove the propellers but it is like they are stocked.
I try to unscrew the propellers but i can’t remove them.
Do you know what to do in this case?
Davide Negro - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 1,888
