Goal Zero Rock Out 2 #94007 Speaker Repair
  1. Goal Zero Rock Out 2 #94007 Speaker Repair, Goal Zero Rock Out 2 #94007 Speaker Repair: step 1, image 1 of 3 Goal Zero Rock Out 2 #94007 Speaker Repair, Goal Zero Rock Out 2 #94007 Speaker Repair: step 1, image 2 of 3 Goal Zero Rock Out 2 #94007 Speaker Repair, Goal Zero Rock Out 2 #94007 Speaker Repair: step 1, image 3 of 3
    • Power off your speaker before beginning disassembly.
    • Use a 2 mm Allen Key to remove eight 13 mm screws from the faceplate.
    • Use a spudger to remove the faceplate and set it aside.
  2. Goal Zero Rock Out 2 #94007 Speaker Repair: step 2, image 1 of 3 Goal Zero Rock Out 2 #94007 Speaker Repair: step 2, image 2 of 3 Goal Zero Rock Out 2 #94007 Speaker Repair: step 2, image 3 of 3
    • Remove the gray center piece and yellow rubber lining.
  3. Goal Zero Rock Out 2 #94007 Speaker Repair: step 3, image 1 of 3 Goal Zero Rock Out 2 #94007 Speaker Repair: step 3, image 2 of 3 Goal Zero Rock Out 2 #94007 Speaker Repair: step 3, image 3 of 3
    • Use a Phillips #0 screwdriver to remove four 12 mm screws from the speaker body.
    • Unzip the speaker case.
    • Turn the the speaker over so the bottom is facing up.
  4. Goal Zero Rock Out 2 #94007 Speaker Repair: step 4, image 1 of 3 Goal Zero Rock Out 2 #94007 Speaker Repair: step 4, image 2 of 3 Goal Zero Rock Out 2 #94007 Speaker Repair: step 4, image 3 of 3
    • Remove speaker from cloth case.
  5. Goal Zero Rock Out 2 #94007 Speaker Repair: step 5, image 1 of 2 Goal Zero Rock Out 2 #94007 Speaker Repair: step 5, image 2 of 2
    • Hold the speaker and gently separate the two parts.
    • Don't yank or pull it apart as the two halves are connected by cables.
  6. Goal Zero Rock Out 2 #94007 Speaker Repair: step 6, image 1 of 3 Goal Zero Rock Out 2 #94007 Speaker Repair: step 6, image 2 of 3 Goal Zero Rock Out 2 #94007 Speaker Repair: step 6, image 3 of 3
    • Use a Phillips #0 screwdriver to remove the four 12 mm screws securing the center resonator.
    • Carefully remove center resonator from the enclosure.
  7. Goal Zero Rock Out 2 #94007 Speaker Repair: step 7, image 1 of 3 Goal Zero Rock Out 2 #94007 Speaker Repair: step 7, image 2 of 3 Goal Zero Rock Out 2 #94007 Speaker Repair: step 7, image 3 of 3
    • This step requires soldering. Soldering can cause injuries such as burns to the skin. It can also produce fumes that are harmful so working in a well-ventilated area is advised.
    • Use wire strippers to remove about 6 mm of insulation from the detached speaker wire.
    • Set the soldering iron to 350 degrees.
    • Add solder to the tip of the iron and then touch the tip to exposed wire.
    • Join the wire with the electrical contact on the speaker.
Ricardo Arevalo Castaneda
157 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 18
All Time: 284
