Golf Club Grip Replacement
  1. Golf Club Grip Replacement, Grip: step 1, image 1 of 2 Golf Club Grip Replacement, Grip: step 1, image 2 of 2
    • Place the golf club securely on a level table.
    • Using a blade or knife, cut a line through the grip.
  2. Golf Club Grip Replacement: step 2, image 1 of 3 Golf Club Grip Replacement: step 2, image 2 of 3 Golf Club Grip Replacement: step 2, image 3 of 3
    • Remove the grip from the golf club shaft.
  3. Golf Club Grip Replacement: step 3, image 1 of 1
    • Use the knife to take off any excess residue from the shaft of the club.
  4. Golf Club Grip Replacement: step 4, image 1 of 2 Golf Club Grip Replacement: step 4, image 2 of 2
    • Apply the double sided tape to the bare shaft in a spiral pattern.
    • Use the grip to determine how far up the shaft the tape needs to go.
  5. Golf Club Grip Replacement: step 5, image 1 of 1
    • Remove the tape backing.
  6. Golf Club Grip Replacement: step 6, image 1 of 3 Golf Club Grip Replacement: step 6, image 2 of 3 Golf Club Grip Replacement: step 6, image 3 of 3
    • Place a golf tee in the hole at the end of the golf grip.
  7. Golf Club Grip Replacement: step 7, image 1 of 2 Golf Club Grip Replacement: step 7, image 2 of 2
    • Pour a generous amount of adhesive into the opposite end of the grip.
    • Squeeze together the open end of the grip.
    • Lightly shake, in order to spread the adhesive within the grip.
  8. Golf Club Grip Replacement: step 8, image 1 of 1
    • Over a bowl or container, pour adhesive in the grip onto the shaft of the golf club.
  9. Golf Club Grip Replacement: step 9, image 1 of 2 Golf Club Grip Replacement: step 9, image 2 of 2
    • Remove the tee from the back of the grip.
    • Push the grip onto the golf club shaft.
    • Ensure that the end of the grip is hitting the end of the shaft.
  10. Golf Club Grip Replacement: step 10, image 1 of 1
    • Allow to dry at least 12 hours before use.
After allowing the club to properly dry, you will have a new grip to improve your swing at tee off.
6 other people completed this guide.
Skylar Nichols
212 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 32
All Time: 7,754
