Golf Club Shaft and Club Head Replacement
  1. Golf Club Shaft and Club Head Replacement, Golf Club Steel Shaft and Grip: step 1, image 1 of 2 Golf Club Shaft and Club Head Replacement, Golf Club Steel Shaft and Grip: step 1, image 2 of 2
    • Using propane or a torch, heat the hosel of the club to remove the steel shaft from the club head. The heat will break the epoxy bond that holds the head to the shaft.
    • Head and shaft will be hot.
  2. Golf Club Shaft and Club Head Replacement: step 2, image 1 of 1
    • Use a wire brush to clean out the remains of the old epoxy from the club head.
  3. Golf Club Shaft and Club Head Replacement: step 3, image 1 of 1
    • Use a piece of sand paper or a grinder to roughen the tip of the shaft where it connects to the hosel of the club head.
  4. Golf Club Shaft and Club Head Replacement: step 4, image 1 of 3 Golf Club Shaft and Club Head Replacement: step 4, image 2 of 3 Golf Club Shaft and Club Head Replacement: step 4, image 3 of 3
    • Pour epoxy into a container and stir to mix it together. Once epoxy is mixed together, spin the shaft tip into the epoxy to prepare for insertion into the head.
  5. Golf Club Shaft and Club Head Replacement: step 5, image 1 of 2 Golf Club Shaft and Club Head Replacement: step 5, image 2 of 2
    • Insert the shaft into the club head. Hold the head and shaft together for approximately 30 seconds to secure.
    • Epoxy cure time may vary by product. In this instance, we let the epoxy set and cure for 24 hours.
  6. Golf Club Shaft and Club Head Replacement: step 6, image 1 of 1
    • To replace the grip of the club, place the club on a level surface where you can cut a straight line through the grip using a razor blade or a utility knife.
  7. Golf Club Shaft and Club Head Replacement: step 7, image 1 of 2 Golf Club Shaft and Club Head Replacement: step 7, image 2 of 2
    • Once the grip is cut, remove the grip and peel off the old tape.
  8. Golf Club Shaft and Club Head Replacement: step 8, image 1 of 3 Golf Club Shaft and Club Head Replacement: step 8, image 2 of 3 Golf Club Shaft and Club Head Replacement: step 8, image 3 of 3
    • Apply the double-sided grip tape to the length of the grip wrapping it around the shaft . Leave 1/2 inch overhang in order to fold in the end of the shaft.
    • Once the tape is fully wrapped around the shaft, smooth out any air bubbles.
    • Remove the backing from the double-sided tape; then twist the overhanging 1/2 inch of tape and push it inside the shaft.
  9. Golf Club Shaft and Club Head Replacement: step 9, image 1 of 3 Golf Club Shaft and Club Head Replacement: step 9, image 2 of 3 Golf Club Shaft and Club Head Replacement: step 9, image 3 of 3
    • Pour grip solvent into the grip, approximately 1/3 full, while holding one finger on the end of the grip to avoid it running out.
    • Shake the grip so the inside of the grip gets all the solvent into it.
    • Pour the excess solvent onto the grip tape around the shaft and have a plate or pan to avoid having a mess. Apply more solvent, if needed, to cover the tape.
  10. Golf Club Shaft and Club Head Replacement: step 10, image 1 of 3 Golf Club Shaft and Club Head Replacement: step 10, image 2 of 3 Golf Club Shaft and Club Head Replacement: step 10, image 3 of 3
    • Align the grip so the decor is facing up and push the grip straight down the shaft. This step needs to be done as soon as possible to avoid getting the grip stuck.
    • Allow it dry for 2-4 hours so the alignment does not get off.
Par!
4 other people completed this guide.
3 Comments
Great description but can you guide us about [|Golf Irons.]
Christina Muller - Reply
How can one remove the hozzle cap of black plastic where the cub head meets the shaft? The heat to remove the old club head will melt this piece and they are hard to find if it has to be replaced.
Tom Bechert - Reply
My Strata 9-iron threw the head and it looks like there is some kind of plastic in the hosel. The shaft fits very loosely within the hole. Do these heads screw in somehow and the plastic piece might be threaded?
Reggie Kenner - Reply
Past 24 Hours: 10
Past 7 Days: 56
Past 30 Days: 288
All Time: 30,705
