Goodman Split Air Conditioner Filter Replacement
  1. Goodman Split Air Conditioner Filter Replacement, Air Filter: step 1, image 1 of 1
    • Turn the unit mode to "off" at thermostat.
  2. Goodman Split Air Conditioner Filter Replacement: step 2, image 1 of 1
    • Locate the filter box.
  3. Goodman Split Air Conditioner Filter Replacement: step 3, image 1 of 2 Goodman Split Air Conditioner Filter Replacement: step 3, image 2 of 2
    • Remove the access cover.
  4. Goodman Split Air Conditioner Filter Replacement: step 4, image 1 of 2 Goodman Split Air Conditioner Filter Replacement: step 4, image 2 of 2
    • Remove (pull) the old filter out.
    • Note the direction of the airflow arrow on the side of filter. This should point in the direction of the airflow from the unit.
  5. Goodman Split Air Conditioner Filter Replacement: step 5, image 1 of 3 Goodman Split Air Conditioner Filter Replacement: step 5, image 2 of 3 Goodman Split Air Conditioner Filter Replacement: step 5, image 3 of 3
    • Insert (slide) the new filter in.
    • Confirm filter dimensions match old filter.
    • Confirm airflow arrow on filter is pointing in the same direction as old filter.
  6. Goodman Split Air Conditioner Filter Replacement: step 6, image 1 of 2 Goodman Split Air Conditioner Filter Replacement: step 6, image 2 of 2
    • Replace the access cover.
  7. Goodman Split Air Conditioner Filter Replacement: step 7, image 1 of 1
    • Turn unit back on at thermostat.
    • Can be cooling or heat depending on time of year.
Follow local guidelines for proper disposal of the old filter.
Replace filter every three months or as needed.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 66
All Time: 1,884
