Google Home Mute Button Switch Replacement
  1. Google Home Mute Button Switch Replacement, Interconnect Cable: step 1, image 1 of 3 Google Home Mute Button Switch Replacement, Interconnect Cable: step 1, image 2 of 3 Google Home Mute Button Switch Replacement, Interconnect Cable: step 1, image 3 of 3
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
  2. Google Home Mute Button Switch Replacement: step 2, image 1 of 1
    Tool used on this step:
    Buy
    • Carefully remove the interconnect cable using a pair of tweezers.
  3. Google Home Mute Button Switch Replacement, Mute Button Switch: step 3, image 1 of 2 Google Home Mute Button Switch Replacement, Mute Button Switch: step 3, image 2 of 2
    • Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
  4. Google Home Mute Button Switch Replacement: step 4, image 1 of 2 Google Home Mute Button Switch Replacement: step 4, image 2 of 2
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws.
    • Remove the panel and the mute button switch. If done correctly you should now be able to see the device’s guitar-shaped motherboard.
Gabe Hyun
844 Reputation
4 Guides authored
Cal Poly, Team S24-G11, Maness Spring 2018 Member of Cal Poly, Team S24-G11, Maness Spring 2018
CPSU-MANESS-S18S24G11
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 9
All Time: 1,054
