Google Pixel 2 Display Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Google Pixel 2 Display Replacement, Display: step 1, image 1 of 2 Google Pixel 2 Display Replacement, Display: step 1, image 2 of 2
    • Heat up the iOpener in the microwave for 30 seconds.
    • Place the iOpener clear-side down on each edge of the phone for approximately 30 seconds.
    • Place the iOpener on top of the screen for an additional 30 seconds.
    • Be careful with the iOpener as it will get extremely hot.
  2. Google Pixel 2 Display Replacement: step 2, image 1 of 3 Google Pixel 2 Display Replacement: step 2, image 2 of 3 Google Pixel 2 Display Replacement: step 2, image 3 of 3
    • Attach the suction cup to the display by placing it on top of the display and pushing down on the top of the cup until it is flat.
    • Separate the display and the device by inserting the plastic opening tool between them and sliding the plastic opening tool along the perimeter of the display.
    • It is normal to hear popping noises as the plastic opening tool breaks the connection between the display and the device.
    • Remove the display from the device by grabbing the ring of the suction cup and pulling up.
  3. Google Pixel 2 Display Replacement: step 3, image 1 of 3 Google Pixel 2 Display Replacement: step 3, image 2 of 3 Google Pixel 2 Display Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the T4 4.0-mm screws from the latch under the display by turning the screwdriver counterclockwise.
    • Pull the latch off of the device by grabbing it with the tweezers and pulling up.
  4. Google Pixel 2 Display Replacement: step 4, image 1 of 1
    • Remove the connector underneath the latch by grabbing it with the tweezers and lifting up.
    • It is normal to hear a popping noise during this step.
    • When reassembling, simply use your finger to pop this piece back into place by pushing it down into the device.
Monica Andres
289 Reputation
2 Guides authored
Cal Poly, Team S18-G5, Livingston Winter 2018 Member of Cal Poly, Team S18-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G5
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 1,201
