Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement
  1. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Prepare your phone for disassembly: step 1, image 1 of 1
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
  2. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Insert an opening pick: step 2, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Insert an opening pick: step 2, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Insert an opening pick: step 2, image 3 of 3
    • Apply a suction cup to the back cover, as close to the center of the bottom edge as possible.
    • While securing the phone with one hand, pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert an opening pick into the gap.
    • If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken back cover.
  3. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the back cover adhesive: step 3, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the back cover adhesive: step 3, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the back cover adhesive: step 3, image 3 of 3
    • During the next two steps, don't insert your opening pick deeper than 3 mm to prevent damaging the metal springs around the frame.
    • Optionally, you can measure and mark your opening pick at 3 mm to help you visualize the length.
    • Remove the suction handle from the back cover.
    • Slide the opening pick around the bottom left corner and up the left edge of the back cover to separate the adhesive.
  4. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 4, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 4, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 4, image 3 of 3
    • Continue sliding the pick around the top left corner and across the top edge of the back cover.
  5. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 5, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 5, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 5, image 3 of 3
    • The adhesive along the right edge of the back cover is thicker than the rest. You'll need to insert your opening pick at a minimum of 4 mm to separate the adhesive.
    • Slide your pick down the right edge and around the bottom right corner to separate the remaining adhesive.
  6. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 6, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 6, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 6, image 3 of 3
    • Don't fully remove the back cover yet, as it's still connected to the phone by a cable.
    • At this point, the back cover should be free from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Lift the bottom edge of the back cover and swing it over the top edge of the phone.
    • Prop up the back cover with your suction handle or a clean, sturdy object—making sure that the cable isn't strained.
  7. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top bracket screw: step 7, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top bracket screw: step 7, image 2 of 2
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • While the Pixel 9 Pro Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 or T4 Torx bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP driver to remove the 3.0 mm‑long screw securing the top bracket.
  8. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top bracket: step 8, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top bracket: step 8, image 2 of 2
    • Use tweezers, or your fingers, to pull the top bracket towards the top of the phone to release it from its clip.
    • Remove the top bracket.
  9. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the back cover cable: step 9, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the back cover cable: step 9, image 2 of 2
    • Insert the tip of your spudger under the bottom edge of the back cover cable press connector.
    • Don't insert your spudger anywhere else, as you risk dislodging surface‑mounted components.
    • Pry up and disconnect the back cover cable.
  10. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the back cover: step 10, image 1 of 1
    • Lift the back cover off the frame and remove it.
  11. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the base battery bracket screws: step 11, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the base battery bracket screws: step 11, image 2 of 2
    • Use a Torx Plus 3IP driver to remove the two 3.0 mm‑long screws securing the base battery bracket.
  12. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the base battery bracket: step 12, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the base battery bracket: step 12, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the base battery bracket: step 12, image 3 of 3
    • Use tweezers, or your fingers, to pull the base battery bracket toward the bottom of the phone to release it from its clip.
    • Remove the base battery bracket.
  13. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the base battery: step 13, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the base battery: step 13, image 2 of 2
    • Insert the tip of your spudger under the bottom left corner of the base battery press connector, near the gold marker.
    • Pry up and disconnect the base battery.
  14. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the USB-C port board cable: step 14, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the USB-C port board cable: step 14, image 2 of 2
    • Use a spudger to pry up and disconnect the USB-C port board cable press connector.
  15. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the vibrator bracket screws: step 15, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the vibrator bracket screws: step 15, image 2 of 2
    • Use a Torx Plus 3IP driver to remove the two 3.0 mm‑long screws securing the vibrator bracket.
  16. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the vibrator bracket: step 16, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the vibrator bracket: step 16, image 2 of 2
    • Use tweezers, or your fingers, to lift the vibrator bracket off the frame and remove it.
  17. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the antenna cable: step 17, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the antenna cable: step 17, image 2 of 2
    • Slide one arm of a pair of angled tweezers under the metal neck of the black antenna cable's connector head on the USB‑C board.
    • Lift straight up to disconnect the cable.
  18. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the inner front camera bracket screws: step 18, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the inner front camera bracket screws: step 18, image 2 of 2
    • Use a Torx Plus 3IP driver to remove the two 2.6 mm‑long screws securing the inner front camera bracket.
  19. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the inner front camera bracket: step 19, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the inner front camera bracket: step 19, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the inner front camera bracket: step 19, image 3 of 3
    • Use tweezers, or your fingers, to lift the inner front camera bracket up and toward the left edge of the phone to release its clips.
    • Remove the inner front camera bracket.
  20. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the inner front camera: step 20, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the inner front camera: step 20, image 2 of 2
    • Use a spudger to pry up and disconnect the inner front camera press connector.
  21. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the inner front camera: step 21, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the inner front camera: step 21, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the inner front camera: step 21, image 3 of 3
    • Use the point of a spudger to pry up the inner front camera and separate the adhesive securing it to the frame.
    • Remove the inner front camera.
  22. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the ultra wideband antenna: step 22, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the ultra wideband antenna: step 22, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the ultra wideband antenna: step 22, image 3 of 3
    • Slide the flat end of a spudger under the ultra wideband antenna to separate the adhesive foam securing it to the frame.
    • Use tweezers, or your fingers, to lift the antenna off the frame to separate any remaining adhesive.
  23. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the ultra wideband bracket screws: step 23, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the ultra wideband bracket screws: step 23, image 2 of 2
    • Use a Torx Plus 3IP driver to remove the two 3.0 mm‑long screws securing the ultra wideband bracket.
  24. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the ultra wideband bracket: step 24, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the ultra wideband bracket: step 24, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the ultra wideband bracket: step 24, image 3 of 3
    • While holding the ultra wideband antenna out of the way, pull the bracket toward the bottom of the phone to release its clips.
    • Remove the ultra wideband bracket.
  25. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the bottom interconnect cable bracket screw: step 25, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the bottom interconnect cable bracket screw: step 25, image 2 of 2
    • Use a Torx Plus 3IP driver to remove the 3.0 mm‑long screw securing the interconnect cable bracket.
  26. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the bottom interconnect cable bracket: step 26, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the bottom interconnect cable bracket: step 26, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the bottom interconnect cable bracket: step 26, image 3 of 3
    • Use tweezers, or your fingers, to pull the bracket toward the right edge of the phone to release its clip.
    • Remove the bottom interconnect cable bracket.
  27. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the inner display cable bracket screw: step 27, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the inner display cable bracket screw: step 27, image 2 of 2
    • Use a Torx Plus 3IP driver to remove the 3.0 mm‑long screw securing the inner display cable bracket.
  28. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the inner display cable bracket: step 28, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the inner display cable bracket: step 28, image 2 of 2
    • Use tweezers, or your fingers, to pull the inner display cable bracket towards the left edge of the phone to release it from its clip.
    • Remove the inner display cable bracket.
  29. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the inner display cable: step 29, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the inner display cable: step 29, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the inner display cable: step 29, image 3 of 3
    • Insert the point of a spudger under the bottom left corner of the inner display press connector, next to the gold marker on the logic board.
    • Pry up and disconnect the inner display cable.
  30. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 30, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 30, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 30, image 3 of 3
    • Repeat the previous step to disconnect the top and bottom interconnect cable press connectors, making sure to only pry next to the gold markers.
  31. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the graphite sheet: step 31, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the graphite sheet: step 31, image 2 of 2
    • Peel the graphite sheet off the bottom speaker to separate the adhesive securing it.
  32. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 32, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 32, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 32, image 3 of 3
    • Continue peeling the graphite sheet off the logic board to separate the remaining adhesive.
  33. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the side buttons: step 33, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the side buttons: step 33, image 2 of 2
    • Use tweezers, or your fingers, to peel off the yellow tape on the side button cable ZIF connector.
    • Set the tape aside. You'll need it during reassembly.
  34. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 34, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 34, image 2 of 2
    • Use the point of a spudger, or your fingernail, to lift the locking tab on the side button cable ZIF connector.
  35. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 35, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 35, image 2 of 2
    • Use angled tweezers to pull the side button cable straight out of its slot.
    • Take care not to puncture the battery—it can leak dangerous chemicals and/or catch fire.
  36. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the 5G mmWave antenna: step 36, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the 5G mmWave antenna: step 36, image 2 of 2
    • A thermal pad lightly adheres the 5G mmWave antenna to the frame.
    • Use the tip of a spudger to pry up the 5G mmWave antenna from the frame and separate it from the thermal pad.
  37. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the logic board screws: step 37, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the logic board screws: step 37, image 2 of 2
    • Use a Torx Plus 3IP driver to remove the three screws securing the logic board:
    • One 2.2 mm‑long screw
    • Two 2.6 mm‑long screws
  38. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the logic board: step 38, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the logic board: step 38, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the logic board: step 38, image 3 of 3
    • Insert the flat end of a spudger under the top left corner of the logic board, next to the inner front camera cutout.
    • You might feel some resistance since the logic board is bonded to the frame by thermal paste.
    • Pry up the logic board enough so you can grip the top edge with your fingers.
  39. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 39, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 39, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 39, image 3 of 3
    • Lift the top of the logic board out of the frame and remove it.
    • Lay down the logic board upside down on a clean surface.
  40. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Clean the thermal paste: step 40, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Clean the thermal paste: step 40, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Clean the thermal paste: step 40, image 3 of 3
    • Use the flat end of a spudger to scrape away large pieces of old thermal paste from the frame.
    • Apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to any remaining thermal paste residue.
    • Wipe away the residue using a coffee filter or lint-free cloth.
  41. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 41, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 41, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 41, image 3 of 3
    • Don't press down heavily on the logic board while cleaning it to prevent bending the metal springs or smudging the rear camera assembly.
    • Repeat the thermal paste cleaning procedure for the bottom of the logic board.
  42. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the conductive fabric: step 42, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the conductive fabric: step 42, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the conductive fabric: step 42, image 3 of 3
    • Use tweezers, or your fingers, to peel the section of conductive fabric connecting the loudspeaker to the frame.
  43. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the cable adhesive: step 43, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the cable adhesive: step 43, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the cable adhesive: step 43, image 3 of 3
    • Slide one arm of a pair of angled tweezers under the contact pad connected to the loudspeaker.
    • Lift the contact pad to separate the adhesive securing it to the frame.
  44. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the loudspeaker screw: step 44, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the loudspeaker screw: step 44, image 2 of 2
    • Use a Torx Plus 3IP driver to remove the 2.6 mm‑long screw securing the loudspeaker.
  45. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the loudspeaker: step 45, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the loudspeaker: step 45, image 2 of 2
    • Use the tip of a spudger to pry up the left edge of the loudspeaker to separate the adhesive securing it to the frame.
  46. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 46, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 46, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 46, image 3 of 3
    • Use your fingers to lift the top edge of the loudspeaker and pull it out of its recess in the frame.
    • Remove the loudspeaker.
  47. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the USB-C port board adhesive: step 47, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the USB-C port board adhesive: step 47, image 2 of 2
    • Slide the tip of an opening pick under the USB-C port board cable to separate the adhesive securing it to the frame.
  48. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the USB-C port board screws: step 48, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the USB-C port board screws: step 48, image 2 of 2
    • Use a Torx Plus 3IP driver to remove the three 2.6 mm‑long screws securing the USB-C port board.
  49. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the USB-C port board: step 49, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the USB-C port board: step 49, image 2 of 2
    • Use a spudger to pry up the top right corner of the USB-C port board to unclip it from the frame.
  50. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 50, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 50, image 2 of 2
    • Pull the USB-C port board out of its recess in the frame and remove it.
  51. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the base battery: step 51, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the base battery: step 51, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the base battery: step 51, image 3 of 3
    • Use your fingers to peel up the two edges of the pull tab on the base battery.
  52. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 52, image 1 of 1
    • Unfold your phone and flip it so the inner screen is facing upward.
    • Use a hair dryer, or a heat gun, to heat the section of inner screen behind the base battery until the its barely too hot to touch.
    • Don't heat the screen longer than 30 seconds, as it's susceptible to heat damage.
  53. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 53, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 53, image 2 of 2
    • Fold your phone and turn it so the base battery is facing up.
    • While holding the right pull tab, slide the left pull tab toward the top edge of the battery to separate the top section of adhesive.
  54. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 54, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 54, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 54, image 3 of 3
    • The battery adhesive is strong. Be careful when pulling on the battery and reapply heat if necessary to avoid bending it.
    • Grip the ends of the plastic pull tabs with your fingers.
    • Pull straight up with constant, steady force to separate the adhesive under the battery. Work slowly and let time do the work for you until the adhesive separates.
    • Remove the base battery.
    • If you're having trouble separating the adhesive, apply more heat and try again.
    • If you're having a lot of trouble separating the adhesive, or if you feel like you might damage the battery, follow the next three steps for an alternate method.
  55. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply isopropyl alcohol: step 55, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply isopropyl alcohol: step 55, image 2 of 2
    • The next two steps show how to apply isopropyl alcohol under the base battery.
    • Apply a few drops of high concentration (>90%) isopropyl alcohol under the bottom edge of the base battery.
  56. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 56, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 56, image 2 of 2
    • Lift the bottom edge of the phone to let the isopropyl alcohol flow under the battery.
    • Wait one minute for the alcohol to soften the adhesive.
  57. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the base battery: step 57, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the base battery: step 57, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the base battery: step 57, image 3 of 3
    • Apply a suction cup to the center of the base battery.
    • While securing the phone with one hand, pull up on the suction cup with strong, steady force to separate the base battery from the frame.
  58. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Heat the vibrator: step 58, image 1 of 1
    • Use a hair dryer, or a heat gun, to heat the vibrator until it's barely too hot to touch.
  59. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the vibrator: step 59, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the vibrator: step 59, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the vibrator: step 59, image 3 of 3
    • Insert one arm of a pair of angled tweezers in the notch at the bottom left corner of the vibrator.
    • Pry up with the tweezers to separate the adhesive securing it to the frame.
    • Remove the vibrator.
  60. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Insert an opening pick: step 60, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Insert an opening pick: step 60, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Insert an opening pick: step 60, image 3 of 3
    • Apply a suction cup to the screen, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the screen and the frame.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the screen.
  61. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the adhesive: step 61, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the adhesive: step 61, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the adhesive: step 61, image 3 of 3
    • During the next four steps, don't insert your opening pick deeper than 3 mm to prevent damaging internal components.
    • Optionally, you can measure and mark your opening pick 3 mm from the tip to help you visualize the length.
    • Slide the opening pick around the bottom right corner and up the right edge of the screen to separate the adhesive.
  62. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 62, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 62, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 62, image 3 of 3
    • Slide the pick around the top right corner and stop before the front camera.
  63. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 63, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 63, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 63, image 3 of 3
    • Pull the opening pick out so only the tip is under the screen.
    • Slide the opening pick across the top edge of the screen until you're past the front camera.
    • Push your pick to its original depth before continuing.
  64. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 64, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 64, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 64, image 3 of 3
    • Slide the opening pick around the top left corner and stop about two‑thirds down the left edge of the screen.
    • Don't slide the pick any farther, or you risk damaging the display cable.
  65. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 65, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 65, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 65, image 3 of 3
    • Pull the opening pick out to a 2 mm depth and rotate the pick around the bottom left corner to separate the remaining adhesive.
  66. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 66, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 66, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 66, image 3 of 3
    • Don't fully remove the screen yet, as it's still connected to the phone by a cable.
    • At this point, the screen should be free from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Lift the right edge of the screen and swing it over the left edge of the phone, like opening a book.
    • Prop up the screen with your suction handle or a clean, sturdy object.
  67. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the display cable bracket screw: step 67, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the display cable bracket screw: step 67, image 2 of 2
    FixMat
    $36.95
    Buy
    • Use a Torx Plus 3IP driver to remove the 2.2 mm‑long screw securing the display cable bracket.
  68. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 68, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 68, image 2 of 2
    • Conductive tape secures the display cable bracket to the frame.
    • Use a spudger, or your fingers, to lift the display cable bracket enough to access the press connector underneath.
  69. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the display cable: step 69, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the display cable: step 69, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the display cable press connector.
  70. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the screen: step 70, image 1 of 1
    • Lift the screen off the frame and remove it.
  71. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the battery bracket screw: step 71, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the battery bracket screw: step 71, image 2 of 2
    • Use a Torx Plus 3IP driver to remove the 2.0 mm‑long screw securing the battery bracket.
  72. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the battery: step 72, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the battery: step 72, image 2 of 2
    • Conductive tape secures the battery connector bracket to the lower board.
    • Use tweezers, or your fingers, to move the battery bracket out of the way of the battery press connector.
  73. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 73, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 73, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the battery press connector.
  74. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the rubber block: step 74, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the rubber block: step 74, image 2 of 2
    • Use tweezers, or your fingers, to remove the rubber block covering a screw on the top board.
  75. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top interconnect cable bracket screws: step 75, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top interconnect cable bracket screws: step 75, image 2 of 2
    • Use a Torx Plus 3IP driver to remove the two 2.2 mm‑long screws securing the top interconnect cable bracket.
  76. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top interconnect cable bracket: step 76, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top interconnect cable bracket: step 76, image 2 of 2
    • Use tweezers, or your fingers, to remove the top interconnect cable bracket.
  77. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the top interconnect cable: step 77, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the top interconnect cable: step 77, image 2 of 2
    • Insert the point of a spudger under the top right corner of the top interconnect cable press connector, near the golden marker.
    • Pry up and disconnect the top interconnect cable press connector.
  78. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the bottom interconnect cable bracket screws: step 78, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the bottom interconnect cable bracket screws: step 78, image 2 of 2
    • Use a Torx Plus 3IP driver to remove the two 2.2 mm‑long screws securing the bottom interconnect cable bracket.
  79. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the bottom interconnect cable bracket: step 79, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the bottom interconnect cable bracket: step 79, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the bottom interconnect cable bracket: step 79, image 3 of 3
    • Use tweezers, or your fingers, to remove the bottom interconnect cable bracket from the lower board.
  80. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the bottom interconnect cable: step 80, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the bottom interconnect cable: step 80, image 2 of 2
    • Insert a spudger under the right edge of the bottom interconnect cable press connector.
    • Pry up and disconnect the bottom interconnect cable.
  81. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the SIM card tray: step 81, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the SIM card tray: step 81, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the SIM card tray: step 81, image 3 of 3
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole and press firmly to eject it.
    • Remove the SIM card tray.
  82. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the battery cable adhesive: step 82, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the battery cable adhesive: step 82, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the battery cable adhesive: step 82, image 3 of 3
    • Slide the flat end of a spudger under the flip battery cable to separate the adhesive.
    • Use tweezers, or your fingers, to lift the flip battery cable connector and fully separate it from the frame.
  83. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the flip battery: step 83, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the flip battery: step 83, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the flip battery: step 83, image 3 of 3
    • Use your fingers to peel both edges of the flip battery pull tabs off the battery.
  84. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 84, image 1 of 1
    • Use a hair dryer, or a heat gun, to heat the section of inner screen behind the flip battery (the side with the SIM card cutout) until it's barely too hot to touch.
  85. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 85, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 85, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 85, image 3 of 3
    • Fold your phone and turn it so the flip battery is facing up.
    • Pull up on alternating sides of the pull tab to slice through the adhesive on the upper half of the flip battery, stopping once you get to the top edge.
    • Try to not lose one of the sides of the pull tab under the battery. If you do, don't worry! Move to the next step for an alternate method to remove the battery.
  86. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply isopropyl alcohol: step 86, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply isopropyl alcohol: step 86, image 2 of 2
    • The remaining adhesive is extremely strong. To avoid bending the battery, the next three steps show how to use isopropyl alcohol and a suction handle to remove it.
    • Apply a few drops of isopropyl alcohol (>90%) under the bottom edge of the flip battery.
  87. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 87, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 87, image 2 of 2
  88. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the flip battery: step 88, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the flip battery: step 88, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the flip battery: step 88, image 3 of 3
    • Apply a suction handle to the center of the flip battery.
    • While securing the phone with one hand, pull up on the suction cup with strong, steady force to separate the flip battery from the frame.
    • If the flip battery doesn't budge after applying constant pressure, apply more isopropyl alcohol and try again.
    • Remove the flip battery.
  89. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top board screw: step 89, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top board screw: step 89, image 2 of 2
    • Use a Torx Plus 3IP driver to remove the 2.2 mm‑long screw securing the top board.
  90. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top board: step 90, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top board: step 90, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top board: step 90, image 3 of 3
    • Insert the flat end of a spudger under the bottom edge of the top board.
    • Twist the spudger to lift the top board enough to unclip it from the frame.
    • Remove the top board.
  91. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, End of disassembly: step 91, image 1 of 1
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
  92. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the top board: step 92, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the top board: step 92, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the top board: step 92, image 3 of 3
    • Press the top edge of the top board against the frame at a downward angle to engage its metal spring.
    • Press the board flat to the frame, making sure the screw holes are aligned.
  93. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 93, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 93, image 2 of 2
    • Use a Torx Plus 3IP driver to install the 2.2 mm‑long screw securing the top board.
  94. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: step 94, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: step 94, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: step 94, image 3 of 3
    • Use tweezers, or your fingers, to remove the old flip battery adhesive from the frame.
  95. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 95, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 95, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 95, image 3 of 3
    • Apply isopropyl alcohol (>90%) and use a coffee filter or microfiber cloth to clean any adhesive residue.
  96. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: step 96, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: step 96, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: step 96, image 3 of 3
    • The adhesives for the flip battery cable and connector are separate from the main adhesive strip.
    • Place the flip battery cable and connector adhesives over the frame, using the white outlines to confirm their orientation.
    • The clear liners should face the frame.
    • Peel the adhesive strips off their liners and place them over their respective spots on the frame.
  97. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 97, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 97, image 2 of 2
    • Use the flat end of a spudger, or your fingers, to press down on the adhesive strips to adhere them to the frame.
  98. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 98, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 98, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 98, image 3 of 3
    • Peel the main flip battery adhesive strip from its clear liner.
    • Align the top edge of the adhesive strip with the top edge of the battery recess.
    • The pull tab should be in the bottom left corner of the frame.
    • Lay the adhesive strip on the frame.
  99. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 99, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 99, image 2 of 2
    • Use the flat end of a spudger, or your fingers, to press down the individual adhesive strips to adhere them to the frame.
  100. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 100, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 100, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 100, image 3 of 3
    • Use the pull tab to peel the colored liner off to expose the adhesive.
  101. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 101, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 101, image 2 of 2
    • Peel off the colored liners on the flip battery cable and connector adhesive.
  102. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Secure the flip battery: step 102, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Secure the flip battery: step 102, image 2 of 2
    • Align the top edge of the flip battery with the top edge of the battery well.
    • Lay the battery over the frame.
  103. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 103, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 103, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 103, image 3 of 3
    • Press down along the perimeter of the flip battery to adhere it to the frame.
    • Press down the flip battery cable and its connector to adhere it.
    • Let the phone sit for an hour for the adhesive to cure.
  104. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinsert the SIM card tray: step 104, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinsert the SIM card tray: step 104, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinsert the SIM card tray: step 104, image 3 of 3
    • While holding the lower board in place, reinsert the SIM card tray.
  105. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the bottom interconnect cable: step 105, image 1 of 1
    • Reconnect the bottom interconnect cable press connector.
  106. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the bottom interconnect cable bracket: step 106, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the bottom interconnect cable bracket: step 106, image 2 of 2
    • Place the bottom interconnect cable bracket on the lower board and align its screw holes.
  107. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 107, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 107, image 2 of 2
    • Use a Torx Plus 3IP driver to install the two 2.2 mm‑long screws securing the bottom interconnect cable bracket.
  108. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the top interconnect cable: step 108, image 1 of 1
    • Reconnect the top interconnect cable press connector.
  109. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the top interconnect cable bracket: step 109, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the top interconnect cable bracket: step 109, image 2 of 2
    • Place the top interconnect cable bracket on the top board and align its screw holes.
  110. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 110, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 110, image 2 of 2
    • Use a Torx Plus 3IP driver to install the two 2.2 mm‑long screws securing the top interconnect cable bracket.
  111. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the rubber block: step 111, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the rubber block: step 111, image 2 of 2
    • Place the rubber block over its spot on the top board and press it down.
  112. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the flip battery: step 112, image 1 of 1
    • Reconnect the flip battery press connector.
  113. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the flip battery bracket: step 113, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the flip battery bracket: step 113, image 2 of 2
    • Lay the flip battery bracket over the press connector and align the screw holes.
  114. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 114, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 114, image 2 of 2
    • Use a Torx Plus 3IP driver to install the 2.0 mm‑long screw securing the battery bracket.
  115. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: step 115, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: step 115, image 2 of 2
    • If your outer screen adhesive at the bottom left corner isn't sticky anymore, follow the next four steps to replace it. Otherwise, skip the next four steps.
    • Use a spudger, or your fingers, to remove the old bottom left outer screen adhesive.
    • Use isopropyl alcohol (>90%) and a coffee filter or a microfiber cloth to remove any adhesive residue.
  116. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Compare your new adhesive: step 116, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Compare your new adhesive: step 116, image 2 of 2
    • Before removing any liners, check if the bottom left outer screen adhesive matches the frame.
    • The clear liner should face the frame.
  117. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: step 117, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: step 117, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: step 117, image 3 of 3
    • Peel the bottom left outer screen adhesive off its clear liner to expose the adhesive.
    • Put the adhesive into place on the frame.
  118. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 118, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 118, image 2 of 2
    • Use the flat end of a spudger to press along the adhesive strip to adhere it to the frame.
  119. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: step 119, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: step 119, image 2 of 2
    • Before removing any liners, check if the perimeter outer screen adhesive matches the frame.
  120. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 120, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 120, image 2 of 2
    • Be careful during this step, as it's easy to stick the adhesive in the wrong spot. Take your time and work slowly.
    • Peel away the top half of the new adhesive strip from its clear liner and keep it folded.
  121. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 121, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 121, image 2 of 2
    • Align the top half of the adhesive over the frame, using the corners as reference points.
    • Place the adhesive on the frame.
  122. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 122, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 122, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 122, image 3 of 3
    • Use the flat end of a spudger, or your fingers, to press down the top edge of the adhesive and adhere it to the frame.
  123. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 123, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 123, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 123, image 3 of 3
    • While peeling away the rest of the clear liner, slowly lay the rest of the adhesive over the perimeter of the phone.
  124. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 124, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 124, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 124, image 3 of 3
    • Use the flat end of a spudger, or your fingers, to press down the rest of the adhesive and adhere it to the frame.
  125. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 125, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 125, image 2 of 2
    • Use the tip of a spudger to pry up the segmented tab on the bottom left corner of the large blue liner.
  126. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 126, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 126, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 126, image 3 of 3
    • Lift the tab and peel off the large blue liner to expose the secondary liner.
    • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it to the frame.
  127. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the outer screen: step 127, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the outer screen: step 127, image 2 of 2
    • Support the screen with your hand or prop it up on something sturdy.
    • Reconnect the outer screen cable press connector.
  128. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the outer screen cable bracket: step 128, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the outer screen cable bracket: step 128, image 2 of 2
    • Reinsert the outer screen cable bracket clip under the frame and align its screw hole.
  129. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 129, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 129, image 2 of 2
    • Use a Torx Plus 3IP driver to install the 2.2 mm‑long screw securing the display cable bracket.
  130. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Expose the adhesive: step 130, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Expose the adhesive: step 130, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Expose the adhesive: step 130, image 3 of 3
    • Remove the blue liner from the bottom left outer screen adhesive strip.
    • While holding the screen above the frame, separate one of the secondary liner's pull tabs at the bottom left corner.
  131. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 131, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 131, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 131, image 3 of 3
    • Still holding the screen, peel off the secondary liner to expose the adhesive.
  132. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Secure the outer screen: step 132, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Secure the outer screen: step 132, image 2 of 2
    • Align the outer screen over the frame and press it into place.
  133. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 133, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 133, image 2 of 2
    • Press along the perimeter of the outer screen to adhere it to the frame.
    • Optionally, you can use a hair dryer or heat gun to lightly heat the edges of the back cover and create a stronger bond.
    • Let the phone sit a few hours for the adhesive to cure.
  134. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the vibrator: step 134, image 1 of 1
    Tesa 61395 Tape
    $5.99
    Buy
    • Flip your phone over.
    • If your replacement inner screen assembly comes with adhesive pre‑installed over the vibrator cutout, remove its liner. Otherwise, use a thin double‑sided tape to replace the adhesive.
    • Align the vibrator over its cutout on the frame and press down to adhere it.
  135. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: step 135, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: step 135, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: step 135, image 3 of 3
    • Use tweezers, or your fingers, to remove the old base battery adhesive from the frame.
  136. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Compare your new adhesive: step 136, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Compare your new adhesive: step 136, image 2 of 2
    • Before removing any liners, check that your base battery adhesive matches the size and shape of the cutout in the frame.
  137. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: step 137, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: step 137, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: step 137, image 3 of 3
    • Peel off the adhesive strip from its clear liner.
    • Align the adhesive strip with the top edge of the base battery recess and press it onto the frame.
  138. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 138, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 138, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 138, image 3 of 3
    • Use the flat end of a spudger, or your fingers, to press down the five adhesive strips and adhere them to the frame.
  139. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 139, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 139, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 139, image 3 of 3
    • Peel off the colored liner to expose the adhesive strips.
  140. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Install the new base battery: step 140, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Install the new base battery: step 140, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Install the new base battery: step 140, image 3 of 3
    • Align the new base battery with the top edge of the battery recess and press it to the frame.
  141. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 141, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 141, image 2 of 2
    • Use your fingers to press along the battery to adhere it to the frame.
  142. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the USB-C port board: step 142, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the USB-C port board: step 142, image 2 of 2
    • Reinsert the USB-C port board into its recess in the frame.
  143. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 143, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 143, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 143, image 3 of 3
    • Press the USB-C port board flat to the frame to re-engage the metal springs, making sure the alignment pegs fit into their holes in the board.
  144. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 144, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 144, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 144, image 3 of 3
    • While holding the board in place, use a Torx Plus 3IP driver to install the three 2.6 mm‑long screws securing the USB-C port board.
  145. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the adhesive: step 145, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the adhesive: step 145, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the adhesive: step 145, image 3 of 3
    • If the adhesive on your USB-C port cable isn't sticky or intact, follow the next two steps to install new adhesive. Otherwise, skip those steps.
    • Use tweezers, or your fingers, to remove the old adhesive under the USB-C port cable.
    • Peel the new USB-C port cable adhesive strip from its clear liner.
    • Align the adhesive strip over its spot in the frame and lay it down with the colored pull tab facing the right edge of the phone.
  146. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 146, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 146, image 2 of 2
    • Use the flat end of a spudger, or your fingers, to press down the adhesive and adhere it to the frame.
    • Peel off the colored liner to expose the adhesive.
  147. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 147, image 1 of 1
    • Press the USB-C port board cable to the frame to re-adhere it.
  148. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: step 148, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: step 148, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: step 148, image 3 of 3
    • The next six steps show how to replace the conductive fabric on the bottom of your loudspeaker and the adhesive on the loudspeaker's cable. Skip these steps if your fabric and adhesive are intact.
    • Use tweezers, or your fingers, to remove the bottom and top conductive fabrics or the loudspeaker cable adhesive if they're not intact.
  149. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the bottom conductive fabric: step 149, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the bottom conductive fabric: step 149, image 2 of 2
    • Align the bottom loudspeaker conductive fabric on the underside of the loudspeaker.
    • Refer to the second photo for the correct orientation.
  150. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 150, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 150, image 2 of 2
    • Remove the conductive fabric from its clear and colored liners and lay it over its spot on the loudspeaker.
  151. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 151, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 151, image 2 of 2
    • Use the flat end of a spudger, or your fingers, to press down the conductive fabric and adhere it to the loudspeaker.
  152. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the adhesive: step 152, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the adhesive: step 152, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the adhesive: step 152, image 3 of 3
    • Peel the clear liner off the loudspeaker cable adhesive.
    • Align the adhesive over the loudspeaker cable and lay it down, making sure not to cover the hole in the cable.
  153. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 153, image 1 of 1
    • Use your fingers to lightly pinch the cable and adhere the adhesive strip.
    • Remove the blue liner from the adhesive strip.
  154. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the loudspeaker: step 154, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the loudspeaker: step 154, image 2 of 2
    • Align the hole in the loudspeaker cable over its peg on the frame.
    • Press down the cable with the tip of a spudger, or your finger, to adhere it to the frame.
  155. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 155, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 155, image 2 of 2
    • While pressing the cable down, reinsert the loudspeaker at an angle into its recess and press it flat to the frame.
  156. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 156, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 156, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 156, image 3 of 3
    • While holding the loudspeaker in place, use a Torx Plus 3IP driver to install the 2.6 mm‑long screw securing the loudspeaker.
  157. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the top conductive fabric: step 157, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the top conductive fabric: step 157, image 2 of 2
    • The next four steps show how to replace the conductive fabric on the top of the loudspeaker. Skip these steps if your fabric is still intact.
    • Peel off the clear liner on the top loudspeaker conductive fabric.
    • Peel off the small colored liner covering the rounded corner of the fabric.
  158. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 158, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 158, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 158, image 3 of 3
    • Align the rounded corner of the conductive fabric with the same‑shaped marking on the frame.
    • Lay the fabric down onto the frame and the loudspeaker.
  159. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 159, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 159, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 159, image 3 of 3
    • Use the flat end of a spudger, or your fingers, to press down the conductive fabric and adhere it to the frame and loudspeaker.
  160. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 160, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 160, image 2 of 2
    • Peel off the large colored liner from the conductive fabric.
  161. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply new thermal paste: step 161, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply new thermal paste: step 161, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply new thermal paste: step 161, image 3 of 3
    • Apply small beads of thermal paste (five total) to the motherboard in the same locations as the old thermal paste.
  162. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the logic board: step 162, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the logic board: step 162, image 2 of 2
    • Place the logic board back into its cutout in the frame, making sure no cables get trapped underneath it.
  163. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 163, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 163, image 2 of 2
    • Use a Torx Plus 3IP driver to install the three screws securing the logic board:
  164. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the side button cable: step 164, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the side button cable: step 164, image 2 of 2
    • Use angled tweezers to push the side button cable back into its slot.
  165. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 165, image 1 of 1
    • Flip the locking tab down and lightly press on it until it clicks into place.
  166. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 166, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 166, image 2 of 2
    • Place the yellow tape over the ZIF connector and its cable.
  167. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new graphite sheet: step 167, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new graphite sheet: step 167, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new graphite sheet: step 167, image 3 of 3
    • Peel the clear liner off your replacement graphite sheet to expose the adhesive on the upper half.
    • Align the upper half of the graphite sheet over the logic board and lay it down.
  168. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 168, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 168, image 2 of 2
    • Use your finger to press down the upper half of the graphite sheet and secure it to the logic board.
  169. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 169, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 169, image 2 of 2
    • Remove the blue liner from the bottom of the graphite sheet to expose the adhesive underneath.
  170. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 170, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 170, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 170, image 3 of 3
    • Drag your finger from the middle section of the graphite sheet to the adhesive spot on the loudspeaker to flatten the graphite sheet and adhere it.
  171. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 171, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 171, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 171, image 3 of 3
    • Grip the pull tab at the top of the graphite sheet and peel off the remaining liner.
  172. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the right side cables: step 172, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the right side cables: step 172, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the right side cables: step 172, image 3 of 3
    • Reconnect the inner display cable and the top and bottom interconnect cable press connectors.
  173. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the inner display cable bracket: step 173, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the inner display cable bracket: step 173, image 2 of 2
    • Reinsert the inner display cable bracket clip under its slot in the logic board and align the screw holes.
  174. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 174, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 174, image 2 of 2
    • Use a Torx Plus 3IP driver to install the 3.0 mm‑long screw securing the inner display cable bracket.
  175. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the bottom interconnect cable bracket: step 175, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the bottom interconnect cable bracket: step 175, image 2 of 2
    • Reinsert the bottom interconnect bracket clip under its slot in the frame and align the screw hole.
  176. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 176, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 176, image 2 of 2
    • Use a Torx Plus 3IP driver to install the 3.0 mm‑long screw securing the interconnect cable bracket.
  177. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the ultra wideband bracket: step 177, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the ultra wideband bracket: step 177, image 2 of 2
    • While holding the ultra wideband antenna out of the way, reinsert the ultra wideband bracket clip under its slot in the frame and align the screw holes.
  178. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 178, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 178, image 2 of 2
    • Use a Torx Plus 3IP driver to install the two 3.0 mm‑long screws securing the ultra wideband bracket.
  179. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Replace the ultra wideband bracket adhesive: step 179, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Replace the ultra wideband bracket adhesive: step 179, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Replace the ultra wideband bracket adhesive: step 179, image 3 of 3
    • If the adhesive on your ultra wideband bracket is still sticky, skip this step.
    • Remove the old adhesive and foam on the ultra wideband bracket and under the antenna.
    • Replace the corresponding adhesive and foam to the bracket and the frame.
    • Press the ultra wideband antenna to the frame and re‑adhere it.
  180. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: step 180, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: step 180, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: step 180, image 3 of 3
    • Use tweezers, or your fingers, to remove the old adhesive foam from the inner front camera cutout.
    • Use isopropyl alcohol (>90% or greater) and a coffee filter or lint‑free cloth to remove any adhesive residue.
  181. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: step 181, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: step 181, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: step 181, image 3 of 3
    • Peel the replacement inner front camera adhesive foam off its clear liner to expose the adhesive underneath.
    • Align the adhesive foam over the cutout in the frame so that the pull tab is facing the bottom of the phone.
    • Place the adhesive in the cutout.
  182. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 182, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 182, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 182, image 3 of 3
    • Use the tip of a spudger to press along the edges of the adhesive foam to secure it to the frame.
  183. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 183, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 183, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 183, image 3 of 3
    • Use tweezers, or your fingers, to peel off the colored liner and expose the adhesive underneath.
  184. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the inner front camera: step 184, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the inner front camera: step 184, image 2 of 2
    • While holding the inner front camera above its cutout, reconnect its press connector.
    • Lay the inner front camera in its cutout and press down to secure it to the adhesive.
  185. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the inner front camera bracket: step 185, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the inner front camera bracket: step 185, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the inner front camera bracket: step 185, image 3 of 3
    • Reinsert the inner front camera bracket clip under its slot in the logic board and align the screw holes.
  186. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 186, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 186, image 2 of 2
    • Use a Torx Plus 3IP driver to install the two 2.6 mm‑long screws securing the inner front camera bracket.
  187. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the antenna cable: step 187, image 1 of 1
    • Use tweezers to hold the antenna cable's connector in place over its socket and gently press down with your finger or a spudger until the connector snaps into place.
  188. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the vibrator bracket: step 188, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the vibrator bracket: step 188, image 2 of 2
    • Place the vibrator bracket on the logic board and align its screw holes.
  189. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 189, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 189, image 2 of 2
    • Use a Torx Plus 3IP driver to install the two 3.0 mm‑long screws securing the vibrator bracket.
  190. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the USB-C port board cable: step 190, image 1 of 1
    • Reconnect the USB-C port board cable press connector.
  191. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the base battery: step 191, image 1 of 1
    • Reconnect the base battery press connector.
  192. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the base battery bracket: step 192, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the base battery bracket: step 192, image 2 of 2
    • Reinsert the base battery bracket clip under its slot in the logic board and align its screw holes.
  193. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 193, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 193, image 2 of 2
    • Use a Torx Plus 3IP driver to install the two 3.0 mm‑long screws securing the base battery bracket.
  194. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: step 194, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: step 194, image 2 of 2
    • Use a spudger, or your fingers, to remove the old back cover adhesive.
  195. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the back cover liners: step 195, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the back cover liners: step 195, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the back cover liners: step 195, image 3 of 3
    • If you're replacing your back cover with a new one, follow the next two steps. Otherwise, skip them.
    • Use tweezers, or your fingers, to remove the three rear camera liners from the inside of your new back cover.
  196. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 196, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 196, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 196, image 3 of 3
    • Peel off the remaining clear liners on the outside of the back cover.
  197. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Compare your adhesive: step 197, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Compare your adhesive: step 197, image 2 of 2
    • Before removing any liners, check if the adhesive matches the frame.
  198. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: step 198, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: step 198, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: step 198, image 3 of 3
    • Peel away the top half of the new adhesive strip from its clear liner and keep it folded before continuing.
  199. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 199, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 199, image 2 of 2
  200. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 200, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 200, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 200, image 3 of 3
  201. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 201, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 201, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 201, image 3 of 3
  202. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 202, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 202, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 202, image 3 of 3
    • Use a spudger to pry up the segmented tab on the bottom right corner of the large blue liner.
    • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it.
  203. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the back cover cable: step 203, image 1 of 1
    • While holding the back cover or propping it up, reconnect the back cover cable.
    • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  204. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the top bracket: step 204, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the top bracket: step 204, image 2 of 2
    • Reinsert the top bracket clip under its slot in the logic board and align its screw hole.
  205. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 205, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 205, image 2 of 2
    • Use a Torx Plus 3IP driver to install the 3.0 mm‑long screw securing the top bracket.
  206. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the secondary liner: step 206, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the secondary liner: step 206, image 2 of 2
    • Use the tip of a spudger to pry up the segmented tab on the top right corner of the secondary liner.
  207. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 207, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 207, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 207, image 3 of 3
    • Peel off the secondary liner to expose the adhesive.
  208. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Secure the back cover: step 208, image 1 of 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Secure the back cover: step 208, image 2 of 2
    • Align the top edge of the back cover with the frame and press down to adhere it.
  209. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 209, image 1 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 209, image 2 of 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: step 209, image 3 of 3
    • Press along the perimeter of the back cover to adhere it to the frame.
Congratulations on completing your repair!
For optimal performance, calibrate your newly installed batteries after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 9 Pro Fold Answers Community for help.
Alex Diaz-Kokaisl
216,000 Reputation
1,047 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,848 Guides authored
5 Guide Comments
The title is incorrect. The manual doesn't show disassembly nor assembly of inner folding screen.
Marc - Reply
I agree. This doesn't show anything to do with inner screen replacement
Gina Kenney -
the inner screen assembly is like part 0 that everything is build around ?
Wouter Hendrickx - Reply
The instructions do not mention removing and/or replacing the inner screen. Only time it's mentioned is to heat it twice.
This needs correction
Austyn - Reply
This device actually has a service kit provided for the inner screen replacements. When replacing the inner screen on this device it comes with the frame and various connectors.
Cici -
Past 24 Hours: 10
Past 7 Days: 60
Past 30 Days: 313
All Time: 5,855
