Google Pixel 9a Battery Replacement
  1. Google Pixel 9a Battery Replacement, Safety precautions: step 1, image 1 of 1
    • Let your Pixel's battery drain completely (until it dies) before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
  2. Google Pixel 9a Battery Replacement, Heat the rear cover: step 2, image 1 of 3 Google Pixel 9a Battery Replacement, Heat the rear cover: step 2, image 2 of 3 Google Pixel 9a Battery Replacement, Heat the rear cover: step 2, image 3 of 3
    • Adhesive secures the rear cover to the frame. Heating the cover softens the adhesive, making it easier to separate.
    • Use a hair dryer to heat the entire rear cover.
    • Only heat your phone so it's just hot to the touch. Extreme heat can damage the rear cover, screen, or battery.
  3. Google Pixel 9a Battery Replacement, Apply a suction handle: step 3, image 1 of 2 Google Pixel 9a Battery Replacement, Apply a suction handle: step 3, image 2 of 2
    • Apply a suction handle near the center of the rear cover's right edge, as close to the edge as possible.
  4. Google Pixel 9a Battery Replacement, Insert an opening pick: step 4, image 1 of 3 Google Pixel 9a Battery Replacement, Insert an opening pick: step 4, image 2 of 3 Google Pixel 9a Battery Replacement, Insert an opening pick: step 4, image 3 of 3
    • Pull up on the suction handle with strong, steady force until a gap forms between the cover and frame.
    • Insert the tip of an opening pick into the gap.
  5. Google Pixel 9a Battery Replacement, Adhesive information: step 5, image 1 of 3 Google Pixel 9a Battery Replacement, Adhesive information: step 5, image 2 of 3 Google Pixel 9a Battery Replacement, Adhesive information: step 5, image 3 of 3
    • The rear cover is secured with adhesive around the perimeter of the frame and near the cameras. Use this picture as a reference while you separate the adhesive.
    • When separating the left and right edge adhesive, don't insert your pick more than 3 mm to avoid damaging the wireless charging coil and its graphite film.
  6. Google Pixel 9a Battery Replacement, Separate the rear cover adhesive: step 6, image 1 of 3 Google Pixel 9a Battery Replacement, Separate the rear cover adhesive: step 6, image 2 of 3 Google Pixel 9a Battery Replacement, Separate the rear cover adhesive: step 6, image 3 of 3
    • If you ever have trouble separating the adhesive, apply more heat and try again.
    • Slide the opening pick up the right edge, around the top right corner, and along the top edge to separate the adhesive securing the rear cover.
  7. Google Pixel 9a Battery Replacement: step 7, image 1 of 3 Google Pixel 9a Battery Replacement: step 7, image 2 of 3 Google Pixel 9a Battery Replacement: step 7, image 3 of 3
    • Insert an opening pick in the initial gap you created near the center of the rear cover's right edge.
    • Slide the opening pick down the right edge, along the bottom edge, and up the left edge to separate the adhesive securing the cover.
  8. Google Pixel 9a Battery Replacement, Separate the camera bezel adhesive: step 8, image 1 of 3 Google Pixel 9a Battery Replacement, Separate the camera bezel adhesive: step 8, image 2 of 3 Google Pixel 9a Battery Replacement, Separate the camera bezel adhesive: step 8, image 3 of 3
    • Insert the flat edge of an opening pick under the top of the rear cover's left edge, near the camera bezel.
    • Twist the pick and apply constant pressure to separate the adhesive around the camera bezel.
  9. Google Pixel 9a Battery Replacement, Remove the rear cover: step 9, image 1 of 2 Google Pixel 9a Battery Replacement, Remove the rear cover: step 9, image 2 of 2
    • Remove the rear cover.
    • If you feel resistance, go back around the perimeter of the cover and use a pick to separate any remaining adhesive.
  10. Google Pixel 9a Battery Replacement, Remove the camera bezel: step 10, image 1 of 3 Google Pixel 9a Battery Replacement, Remove the camera bezel: step 10, image 2 of 3 Google Pixel 9a Battery Replacement, Remove the camera bezel: step 10, image 3 of 3
    • If the camera bezel detached from the rear cover and stayed stuck to your phone, follow this step to remove it. Otherwise, skip this step.
    • Slide an opening pick under the camera bezel and pry up to remove it.
    • Only insert the pick a few millimeters under the bezel, or you risk damaging the cameras.
    • If you're having trouble, lightly heat the camera bezel.
  11. Google Pixel 9a Battery Replacement, Remove the wireless charging assembly screws: step 11, image 1 of 2 Google Pixel 9a Battery Replacement, Remove the wireless charging assembly screws: step 11, image 2 of 2
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Use a Torx Plus 3IP screwdriver to remove the 16 screws securing the wireless charging assembly:
    • Thirteen 5.0 mm‑long screws
    • Three 2.2 mm‑long screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
  12. Google Pixel 9a Battery Replacement, Unclip the wireless charging assembly: step 12, image 1 of 3 Google Pixel 9a Battery Replacement, Unclip the wireless charging assembly: step 12, image 2 of 3 Google Pixel 9a Battery Replacement, Unclip the wireless charging assembly: step 12, image 3 of 3
  13. Google Pixel 9a Battery Replacement, Remove the wireless charging assembly: step 13, image 1 of 2 Google Pixel 9a Battery Replacement, Remove the wireless charging assembly: step 13, image 2 of 2
    • Remove the wireless charging assembly.
  14. Google Pixel 9a Battery Replacement, Remove the connector cover screw: step 14, image 1 of 2 Google Pixel 9a Battery Replacement, Remove the connector cover screw: step 14, image 2 of 2
    • Be careful not to damage the battery with your tools while disconnecting it.
    • Use a Torx Plus 3IP screwdriver to remove the 1.7 mm‑long screw securing the battery connector cover.
  15. Google Pixel 9a Battery Replacement, Remove the battery connector cover: step 15, image 1 of 3 Google Pixel 9a Battery Replacement, Remove the battery connector cover: step 15, image 2 of 3 Google Pixel 9a Battery Replacement, Remove the battery connector cover: step 15, image 3 of 3
    • Use tweezers to lift and remove the battery connector cover.
  16. Google Pixel 9a Battery Replacement, Disconnect the battery: step 16, image 1 of 2 Google Pixel 9a Battery Replacement, Disconnect the battery: step 16, image 2 of 2
    • Use a spudger to pry up and disconnect the battery cable press connector.
  17. Careful: steps 17-25 are sourced from a guide that's marked as in-progress.
    Google Pixel 9a Battery Replacement, Move the side button cable: step 17, image 1 of 3 Google Pixel 9a Battery Replacement, Move the side button cable: step 17, image 2 of 3 Google Pixel 9a Battery Replacement, Move the side button cable: step 17, image 3 of 3
    • The side button cable is delicate—be careful not to damage it.
    • Use your fingernail or a spudger to gently peel up the side button cable and flip it over the side of your phone.
    • If you use a spudger, be very careful not to poke the battery.
  18. Google Pixel 9a Battery Replacement, Detach the battery pull tabs: step 18, image 1 of 3 Google Pixel 9a Battery Replacement, Detach the battery pull tabs: step 18, image 2 of 3 Google Pixel 9a Battery Replacement, Detach the battery pull tabs: step 18, image 3 of 3
    Finger Stalls
    $8.99
    Buy
    • Use your fingers to peel up the two plastic tabs near the bottom edge of the battery.
    • Fold the tabs under the phone or tape them out of the way so they don't warp when heating the battery in the next step.
    • Wear finger stalls to help get a solid grip on the battery pull tabs in the next few steps.
    • If you don't have finger stalls, use latex/nitrile or rubber gloves instead.
  19. Google Pixel 9a Battery Replacement, Heat the battery: step 19, image 1 of 1
    • Before starting the battery removal process, carefully read the next three steps. The pull tabs are most effective immediately after heating the battery, so you'll want to know exactly what to do before starting the process.
    • Very strong strips of adhesive secure the battery to the frame. Heating the battery will soften the adhesive underneath, making it easier to separate.
    • Use a hair dryer on High heat and Low airspeed settings to heat the battery for three minutes, while holding the hair dryer about three inches from the battery, and moving it constantly. Try to evenly spread the heat over the entire surface of the battery—don't hover in one place for too long.
    • Alternatively, you can use a heat mat at 80 °C (176 °F) with your phone placed screen-side down for 10 minutes.
  20. Google Pixel 9a Battery Replacement, Secure the phone to your work surface: step 20, image 1 of 2 Google Pixel 9a Battery Replacement, Secure the phone to your work surface: step 20, image 2 of 2
    Heavy-Duty F-Clamp
    $13.99
    Buy
    • Since the battery pull tabs require two hands, you'll need to firmly secure the phone to your work surface.
    • Before securing your phone, clean the work surface, making sure nothing is under the screen.
    • Only secure the phone by the raised lip of the frame, and be very careful not to clamp down on any internal components.
    • Use F‑Clamps or C‑Clamps to secure the phone to your work surface. At minimum, you'll need two clamps—one for the top edge and one for the bottom edge.
    • Use clamps with plastic or rubber pads. If using metal clamps, place a cloth between the frame and the clamp to avoid marring the metal frame.
    • If you don't have any clamps, have a friend hold the phone firmly in place.
    • Make sure to follow ESD precautions when securing the phone.
  21. Google Pixel 9a Battery Replacement, Separate the battery adhesive: step 21, image 1 of 3 Google Pixel 9a Battery Replacement, Separate the battery adhesive: step 21, image 2 of 3 Google Pixel 9a Battery Replacement, Separate the battery adhesive: step 21, image 3 of 3
    • Pull straight up on the battery pull tabs and apply constant, steady pressure until the battery separates from the frame. Don't yank on the tabs or the may rip.
    • If the battery doesn't separate after one minute of steady pressure, apply more heat and try again.
    • Remove the battery.
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
    • If you successfully removed the battery, congratulations! Skip down five steps for reassembly information.
    • If the pull tabs broke or accidentally slipped out from under the battery, don't worry! Go to the next step for an alternate battery removal method.
  22. Google Pixel 9a Battery Replacement, Apply isopropyl alcohol: step 22, image 1 of 2 Google Pixel 9a Battery Replacement, Apply isopropyl alcohol: step 22, image 2 of 2
    • During the next two steps, don't apply more isopropyl alcohol than instructed, or you may damage your screen.
    • Apply two or three drops of high-concentration (>90%) isopropyl alcohol to the top right and bottom right corners of the battery.
    • Wait one minute to allow the alcohol to soften the battery adhesive.
  23. Google Pixel 9a Battery Replacement, Apply a suction handle to the battery: step 23, image 1 of 3 Google Pixel 9a Battery Replacement, Apply a suction handle to the battery: step 23, image 2 of 3 Google Pixel 9a Battery Replacement, Apply a suction handle to the battery: step 23, image 3 of 3
    • Apply a suction handle to the center of the battery, so the vertical arm is facing the right edge.
    • Insert the short edge of a plastic card between the right edge of the battery and the logic board, so the card is near the upper section of the battery.
  24. Google Pixel 9a Battery Replacement, Separate the battery adhesive: step 24, image 1 of 3 Google Pixel 9a Battery Replacement, Separate the battery adhesive: step 24, image 2 of 3 Google Pixel 9a Battery Replacement, Separate the battery adhesive: step 24, image 3 of 3
    • Pull up on the suction handle with strong, steady force and pry up with the plastic card until it slides under the battery.
    • It takes time and constant pressure to get the plastic card under the battery.
    • Continue pulling up on the suction handle and slide the plastic card fully under the battery to separate its adhesive.
  25. Google Pixel 9a Battery Replacement, Remove the battery: step 25, image 1 of 3 Google Pixel 9a Battery Replacement, Remove the battery: step 25, image 2 of 3 Google Pixel 9a Battery Replacement, Remove the battery: step 25, image 3 of 3
    • Use the suction handle to lift and remove the battery.
  26. Google Pixel 9a Battery Replacement, Disassembly complete: step 26, image 1 of 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your phone.
  27. Google Pixel 9a Battery Replacement, Remove the old battery adhesive: step 27, image 1 of 3 Google Pixel 9a Battery Replacement, Remove the old battery adhesive: step 27, image 2 of 3 Google Pixel 9a Battery Replacement, Remove the old battery adhesive: step 27, image 3 of 3
    • Use a spudger and tweezers to remove all the old battery adhesive from the frame.
    • The adhesive can be tricky to remove. Use your spudger to roll the adhesive into bigger clumps that you can peel up slowly with tweezers.
  28. Google Pixel 9a Battery Replacement, Clean the frame: step 28, image 1 of 1
    • Use high‑concentration (>90%) isopropyl alcohol and a lint‑free cloth (or coffee filters) to clean up and remove all the old adhesive residue from the frame.
    • Apply isopropyl alcohol sparingly—too much can damage the display.
  29. Google Pixel 9a Battery Replacement, Apply the battery adhesive: step 29, image 1 of 3 Google Pixel 9a Battery Replacement, Apply the battery adhesive: step 29, image 2 of 3 Google Pixel 9a Battery Replacement, Apply the battery adhesive: step 29, image 3 of 3
    • Remove the larger, clear liner from your replacement battery adhesive.
    • Lay the adhesive into the battery recess so the strips align with their contours on the frame.
  30. Google Pixel 9a Battery Replacement: step 30, image 1 of 3 Google Pixel 9a Battery Replacement: step 30, image 2 of 3 Google Pixel 9a Battery Replacement: step 30, image 3 of 3
    • Use your fingers or a spudger to firmly press the adhesive into place, securing it to the frame.
  31. Google Pixel 9a Battery Replacement, Remove the plastic liner: step 31, image 1 of 3 Google Pixel 9a Battery Replacement, Remove the plastic liner: step 31, image 2 of 3 Google Pixel 9a Battery Replacement, Remove the plastic liner: step 31, image 3 of 3
    • Peel up and remove the remaining liner.
  32. Google Pixel 9a Battery Replacement, Move the side button cable: step 32, image 1 of 1
    • Gently flip the side button cable over the frame so it doesn't get stuck between the side of the battery and the frame in the next step.
  33. Google Pixel 9a Battery Replacement, Install the battery: step 33, image 1 of 3 Google Pixel 9a Battery Replacement, Install the battery: step 33, image 2 of 3 Google Pixel 9a Battery Replacement, Install the battery: step 33, image 3 of 3
    • Hold the battery above its recess and use your finger to push down and reconnect the battery press connector.
    • Temporarily reconnecting the battery ensures that it's sitting properly in its recess.
    • Lay the battery into its recess and press down firmly to secure it to the adhesive.
    • Once the battery's in place, disconnect it while you continue reassembly.
  34. Google Pixel 9a Battery Replacement, Secure the side button cable: step 34, image 1 of 3 Google Pixel 9a Battery Replacement, Secure the side button cable: step 34, image 2 of 3 Google Pixel 9a Battery Replacement, Secure the side button cable: step 34, image 3 of 3
    • Use your finger to flip the side button cable onto the battery and gently press down to secure it with its tape.
  35. Google Pixel 9a Battery Replacement, Remove the old adhesive: step 35, image 1 of 2 Google Pixel 9a Battery Replacement, Remove the old adhesive: step 35, image 2 of 2
    • Use a spudger to scrape up and remove the six small pieces of adhesive around the rear cameras.
    • Use high‑concentration (>90%) isopropyl alcohol and a lint‑free cloth (or coffee filter) to clean up and remove any residue from the adhesives that were removed.
  36. Google Pixel 9a Battery Replacement, Apply the adhesive: step 36, image 1 of 3 Google Pixel 9a Battery Replacement, Apply the adhesive: step 36, image 2 of 3 Google Pixel 9a Battery Replacement, Apply the adhesive: step 36, image 3 of 3
    • Remove the larger, clear liner from the inner housing adhesive and lay it in place around the camera holes.
    • Use the cutouts for the small silver pads to help align the adhesive.
    • Use the flat end of a spudger to firmly push down on each piece of adhesive, securing them in place.
    • Remove the colored liner using the pull tab on the top edge.
    • If the adhesive starts to pull up with the liner, lay it back in place and use your spudger to secure it again.
  37. Google Pixel 9a Battery Replacement, Secure the adhesive: step 37, image 1 of 3 Google Pixel 9a Battery Replacement, Secure the adhesive: step 37, image 2 of 3 Google Pixel 9a Battery Replacement, Secure the adhesive: step 37, image 3 of 3
    • Use a spudger to firmly press down on each of the six pieces of inner housing adhesive to secure them.
    • These pieces of adhesive can easily be pulled up when removing the final liners, so make sure they're firmly in place.
  38. Google Pixel 9a Battery Replacement, Connect the battery press connector: step 38, image 1 of 2 Google Pixel 9a Battery Replacement, Connect the battery press connector: step 38, image 2 of 2
    • Use your finger to align the battery press connector over its socket and press down to connect it.
    • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  39. Google Pixel 9a Battery Replacement, Install the battery connector cover: step 39, image 1 of 3 Google Pixel 9a Battery Replacement, Install the battery connector cover: step 39, image 2 of 3 Google Pixel 9a Battery Replacement, Install the battery connector cover: step 39, image 3 of 3
    • Use tweezers to hook the left edge of the battery connector cover into place, then lay the cover down flat.
  40. Google Pixel 9a Battery Replacement: step 40, image 1 of 2 Google Pixel 9a Battery Replacement: step 40, image 2 of 2
    • Use a 3IP Torx Plus screwdriver to install the 1.7 mm‑long screw securing the battery connector cover.
  41. Google Pixel 9a Battery Replacement, Install the wireless charging assembly: step 41, image 1 of 2 Google Pixel 9a Battery Replacement, Install the wireless charging assembly: step 41, image 2 of 2
    • Place the wireless charging assembly onto the frame.
  42. Google Pixel 9a Battery Replacement: step 42, image 1 of 3 Google Pixel 9a Battery Replacement: step 42, image 2 of 3 Google Pixel 9a Battery Replacement: step 42, image 3 of 3
    • Use your fingers to firmly press around the perimeter of the wireless charging assembly to re‑engage all of its clips.
  43. Google Pixel 9a Battery Replacement, Install the wireless charging assembly screws: step 43, image 1 of 2 Google Pixel 9a Battery Replacement, Install the wireless charging assembly screws: step 43, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to install the 16 screws securing the wireless charging assembly:
  44. Google Pixel 9a Battery Replacement, Remove the old rear cover adhesive: step 44, image 1 of 3 Google Pixel 9a Battery Replacement, Remove the old rear cover adhesive: step 44, image 2 of 3 Google Pixel 9a Battery Replacement, Remove the old rear cover adhesive: step 44, image 3 of 3
    • Take your time during the next two steps. A clean frame allows replacement adhesive to lay evenly, ensuring a better bond.
    • When removing the rear cover adhesive during this step, be very careful not to damage the battery or any of the fragile components near the perimeter of the frame.
    • Use a spudger and tweezers to scrape up and remove all the old rear cover adhesive from the perimeter of your phone.
    • If you scrape up a piece big enough to grip with your fingers, you can pull long sections of the adhesive up. Pull slowly and straight in the opposite direction of the adhesive.
  45. Google Pixel 9a Battery Replacement, Clean the frame: step 45, image 1 of 1
    • Using some high-concentration (>90%) isopropyl alcohol and a lint‑free cloth (or coffee filter), clean the areas of the frame where the adhesive was.
  46. Google Pixel 9a Battery Replacement, Find the adhesive orientation: step 46, image 1 of 2 Google Pixel 9a Battery Replacement, Find the adhesive orientation: step 46, image 2 of 2
    • Before applying the rear cover adhesive, make sure you know how it will sit on the frame. If you apply the adhesive incorrectly, you'll need to restart with new adhesive.
    • Hold the adhesive above the frame to find its orientation. Use the camera cutout in the liner to help visualize how it will lay on the frame.
  47. Google Pixel 9a Battery Replacement, Peel the liner halfway down: step 47, image 1 of 1
    • Peel down the top half of the large, clear liner to expose the adhesive—don't fully remove the liner yet.
  48. Google Pixel 9a Battery Replacement, Apply the adhesive: step 48, image 1 of 3 Google Pixel 9a Battery Replacement, Apply the adhesive: step 48, image 2 of 3 Google Pixel 9a Battery Replacement, Apply the adhesive: step 48, image 3 of 3
    • Take your time aligning the adhesive with the frame—it's very sticky and can't be moved once you apply it.
    • With the larger, clear liner folded towards the bottom of the phone, lay the exposed top edge of the adhesive onto the frame.
    • Use the lip of the frame to help align the adhesive.
    • Once the top edge is properly aligned, gently press down on the top corners with your fingers to secure the adhesive.
  49. Google Pixel 9a Battery Replacement: step 49, image 1 of 3 Google Pixel 9a Battery Replacement: step 49, image 2 of 3 Google Pixel 9a Battery Replacement: step 49, image 3 of 3
    • Slowly lay the rest of the adhesive onto the frame, pressing it into place and peeling away the larger liner as you go.
  50. Google Pixel 9a Battery Replacement, Remove the top liner: step 50, image 1 of 3 Google Pixel 9a Battery Replacement, Remove the top liner: step 50, image 2 of 3 Google Pixel 9a Battery Replacement, Remove the top liner: step 50, image 3 of 3
    • Use the pull tab to remove the large, colored liner.
  51. Google Pixel 9a Battery Replacement, Secure the adhesive: step 51, image 1 of 3 Google Pixel 9a Battery Replacement, Secure the adhesive: step 51, image 2 of 3 Google Pixel 9a Battery Replacement, Secure the adhesive: step 51, image 3 of 3
    • Use a spudger to press down firmly on the adhesive around the perimeter of your phone to secure it to the frame.
  52. Google Pixel 9a Battery Replacement, Remove the old camera bezel adhesive: step 52, image 1 of 2 Google Pixel 9a Battery Replacement, Remove the old camera bezel adhesive: step 52, image 2 of 2
    • If the camera bezel detached when removing the rear cover, follow the next five steps to install it. Otherwise, skip down five steps.
    • Use a spudger to scrape up and remove any of the old adhesive from the camera bezel and its corresponding spot on the rear cover.
  53. Google Pixel 9a Battery Replacement, Remove the adhesive residue: step 53, image 1 of 2 Google Pixel 9a Battery Replacement, Remove the adhesive residue: step 53, image 2 of 2
    • Use high-concentration (>90%) isopropyl alcohol and a lint‑free cloth (or coffee filter) to clean up and remove any adhesive residue from the camera bezel and its corresponding spot on the rear cover.
  54. Google Pixel 9a Battery Replacement, Apply the adhesive: step 54, image 1 of 2 Google Pixel 9a Battery Replacement, Apply the adhesive: step 54, image 2 of 2
    • Remove the large, clear liner from the camera bezel adhesive.
    • Put the adhesive over the top of the camera bezel and set it in place.
  55. Google Pixel 9a Battery Replacement: step 55, image 1 of 3 Google Pixel 9a Battery Replacement: step 55, image 2 of 3 Google Pixel 9a Battery Replacement: step 55, image 3 of 3
    • Use a spudger to firmly press around the perimeter of the camera bezel to secure the adhesive.
    • Remove the second, colored liner from the camera bezel adhesive.
  56. Google Pixel 9a Battery Replacement, Install the camera bezel: step 56, image 1 of 2 Google Pixel 9a Battery Replacement, Install the camera bezel: step 56, image 2 of 2
    • Align the camera bezel such that the square foam is closest to the edge.
    • Use your fingers to press the camera bezel into place on the rear cover, squeezing firmly around the perimeter to secure it with the adhesive.
  57. Google Pixel 9a Battery Replacement, Remove the old rear cover adhesive: step 57, image 1 of 2 Google Pixel 9a Battery Replacement, Remove the old rear cover adhesive: step 57, image 2 of 2
    • Use the flat end of a spudger to scrape up and remove any all the old adhesive that stayed on the back cover, including the five pieces of small, oval‑shaped adhesive.
    • If you don't see all the oval adhesives, some might've stuck to the phone frame.
  58. Google Pixel 9a Battery Replacement: step 58, image 1 of 1
    • Use high‑concentration (>90%) isopropyl alcohol and a lint‑free cloth (or coffee filter) to clean up and remove any residue from the adhesives you removed.
  59. Google Pixel 9a Battery Replacement, Apply the adhesive: step 59, image 1 of 2 Google Pixel 9a Battery Replacement, Apply the adhesive: step 59, image 2 of 2
    • Remove the larger, clear liner from the back cover inner adhesive.
    • Lay the adhesive onto the bottom of the back cover, making sure the cutout goes around the camera bezel.
  60. Google Pixel 9a Battery Replacement, Secure the adhesive: step 60, image 1 of 2 Google Pixel 9a Battery Replacement, Secure the adhesive: step 60, image 2 of 2
    • Use your fingers or a spudger to firmly push down on the five small adhesives to secure them to the back cover.
    • Slowly peel up and remove the remaining liner.
    • If the adhesives start to peel up with the liner, lay it back down and use your spudger to secure the adhesive again.
  61. Google Pixel 9a Battery Replacement, Remove the remaining liners: step 61, image 1 of 3 Google Pixel 9a Battery Replacement, Remove the remaining liners: step 61, image 2 of 3 Google Pixel 9a Battery Replacement, Remove the remaining liners: step 61, image 3 of 3
    • Use the point of a spudger to lift and remove the plastic liners from the adhesive around the rear cameras.
  62. Google Pixel 9a Battery Replacement: step 62, image 1 of 2 Google Pixel 9a Battery Replacement: step 62, image 2 of 2
    • Use the pull tabs to remove the final liner from the rear cover adhesive.
  63. Google Pixel 9a Battery Replacement, Install the rear cover: step 63, image 1 of 3 Google Pixel 9a Battery Replacement, Install the rear cover: step 63, image 2 of 3 Google Pixel 9a Battery Replacement, Install the rear cover: step 63, image 3 of 3
    • Align the rear cover over the frame and press it into place.
  64. Google Pixel 9a Battery Replacement: step 64, image 1 of 3 Google Pixel 9a Battery Replacement: step 64, image 2 of 3 Google Pixel 9a Battery Replacement: step 64, image 3 of 3
Congratulations on completing your repair!
For optimal performance, calibrate your newly installed battery after completing this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
2 other people completed this guide.
Spencer Day
163,808 Reputation
1,043 Guides authored
iFixit Member of iFixit
Staff
124 Members
24,241 Guides authored
0 Guide Comments
Past 24 Hours: 59
Past 7 Days: 377
Past 30 Days: 1,433
All Time: 16,014
