Google Pixel 9a Front Camera Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Google Pixel 9a Front Camera Removal, Safety precautions: step 1, image 1 of 2 Google Pixel 9a Front Camera Removal, Safety precautions: step 1, image 2 of 2
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
  2. Google Pixel 9a Front Camera Removal, Heat the rear cover: step 2, image 1 of 3 Google Pixel 9a Front Camera Removal, Heat the rear cover: step 2, image 2 of 3 Google Pixel 9a Front Camera Removal, Heat the rear cover: step 2, image 3 of 3
    • Adhesive secures the rear cover to the frame. Heating the cover softens the adhesive, making it easier to separate.
    • Use a hair dryer to heat the entire rear cover.
    • Only heat your phone so it's just hot to the touch. Extreme heat can damage the rear cover, screen, or battery.
  3. Google Pixel 9a Front Camera Removal, Apply a suction handle: step 3, image 1 of 2 Google Pixel 9a Front Camera Removal, Apply a suction handle: step 3, image 2 of 2
    • Apply a suction handle near the center of the rear cover's right edge, as close to the edge as possible.
  4. Google Pixel 9a Front Camera Removal, Insert an opening pick: step 4, image 1 of 3 Google Pixel 9a Front Camera Removal, Insert an opening pick: step 4, image 2 of 3 Google Pixel 9a Front Camera Removal, Insert an opening pick: step 4, image 3 of 3
    • Pull up on the suction handle with strong, steady force until a gap forms between the cover and frame.
    • Insert the tip of an opening pick into the gap.
  5. Google Pixel 9a Front Camera Removal, Adhesive information: step 5, image 1 of 3 Google Pixel 9a Front Camera Removal, Adhesive information: step 5, image 2 of 3 Google Pixel 9a Front Camera Removal, Adhesive information: step 5, image 3 of 3
    • The rear cover is secured with adhesive around the perimeter of the frame and near the cameras. Use this picture as a reference while you separate the adhesive.
    • When separating the left and right edge adhesive, don't insert your pick more than 3 mm to avoid damaging the wireless charging coil and its graphite film.
  6. Google Pixel 9a Front Camera Removal, Separate the rear cover adhesive: step 6, image 1 of 3 Google Pixel 9a Front Camera Removal, Separate the rear cover adhesive: step 6, image 2 of 3 Google Pixel 9a Front Camera Removal, Separate the rear cover adhesive: step 6, image 3 of 3
    • If you ever have trouble separating the adhesive, apply more heat and try again.
    • Slide the opening pick up the right edge, around the top right corner, and along the top edge to separate the adhesive securing the rear cover.
  7. Google Pixel 9a Front Camera Removal: step 7, image 1 of 3 Google Pixel 9a Front Camera Removal: step 7, image 2 of 3 Google Pixel 9a Front Camera Removal: step 7, image 3 of 3
    • Insert an opening pick in the initial gap you created near the center of the rear cover's right edge.
    • Slide the opening pick down the right edge, along the bottom edge, and up the left edge to separate the adhesive securing the cover.
  8. Google Pixel 9a Front Camera Removal, Separate the camera bezel adhesive: step 8, image 1 of 3 Google Pixel 9a Front Camera Removal, Separate the camera bezel adhesive: step 8, image 2 of 3 Google Pixel 9a Front Camera Removal, Separate the camera bezel adhesive: step 8, image 3 of 3
    • Insert the flat edge of an opening pick under the top of the rear cover's left edge, near the camera bezel.
    • Twist the pick and apply constant pressure to separate the adhesive around the camera bezel.
  9. Google Pixel 9a Front Camera Removal, Remove the rear cover: step 9, image 1 of 2 Google Pixel 9a Front Camera Removal, Remove the rear cover: step 9, image 2 of 2
    • Remove the rear cover.
    • If you feel resistance, go back around the perimeter of the cover and use a pick to separate any remaining adhesive.
  10. Google Pixel 9a Front Camera Removal, Remove the camera bezel: step 10, image 1 of 3 Google Pixel 9a Front Camera Removal, Remove the camera bezel: step 10, image 2 of 3 Google Pixel 9a Front Camera Removal, Remove the camera bezel: step 10, image 3 of 3
    • If the camera bezel detached from the rear cover and stayed stuck to your phone, follow this step to remove it. Otherwise, skip this step.
    • Slide an opening pick under the camera bezel and pry up to remove it.
    • Only insert the pick a few millimeters under the bezel, or you risk damaging the cameras.
    • If you're having trouble, lightly heat the camera bezel.
  11. Google Pixel 9a Front Camera Removal, Remove the wireless charging assembly screws: step 11, image 1 of 2 Google Pixel 9a Front Camera Removal, Remove the wireless charging assembly screws: step 11, image 2 of 2
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Use a Torx Plus 3IP screwdriver to remove the 16 screws securing the wireless charging assembly:
    • Thirteen 5.0 mm‑long screws
    • Three 2.2 mm‑long screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
  12. Google Pixel 9a Front Camera Removal, Unclip the wireless charging assembly: step 12, image 1 of 3 Google Pixel 9a Front Camera Removal, Unclip the wireless charging assembly: step 12, image 2 of 3 Google Pixel 9a Front Camera Removal, Unclip the wireless charging assembly: step 12, image 3 of 3
  13. Google Pixel 9a Front Camera Removal, Remove the wireless charging assembly: step 13, image 1 of 2 Google Pixel 9a Front Camera Removal, Remove the wireless charging assembly: step 13, image 2 of 2
    • Remove the wireless charging assembly.
  14. Google Pixel 9a Front Camera Removal, Remove the connector cover screw: step 14, image 1 of 2 Google Pixel 9a Front Camera Removal, Remove the connector cover screw: step 14, image 2 of 2
    • Be careful not to damage the battery with your tools while disconnecting it.
    • Use a Torx Plus 3IP screwdriver to remove the 1.7 mm‑long screw securing the battery connector cover.
  15. Google Pixel 9a Front Camera Removal, Remove the battery connector cover: step 15, image 1 of 3 Google Pixel 9a Front Camera Removal, Remove the battery connector cover: step 15, image 2 of 3 Google Pixel 9a Front Camera Removal, Remove the battery connector cover: step 15, image 3 of 3
    • Use tweezers to lift and remove the battery connector cover.
  16. Google Pixel 9a Front Camera Removal, Disconnect the battery: step 16, image 1 of 2 Google Pixel 9a Front Camera Removal, Disconnect the battery: step 16, image 2 of 2
    • Use a spudger to pry up and disconnect the battery cable press connector.
  17. Google Pixel 9a Front Camera Removal, Disconnect the front camera: step 17, image 1 of 2 Google Pixel 9a Front Camera Removal, Disconnect the front camera: step 17, image 2 of 2
    • Be very careful not to touch the camera lenses when removing the front camera. If you accidentally do, use a clean cloth to wipe them off.
    • Use the point of a spudger to pry up and disconnect the front camera press connector, prying under the top left corner.
  18. Google Pixel 9a Front Camera Removal, Remove the front camera: step 18, image 1 of 3 Google Pixel 9a Front Camera Removal, Remove the front camera: step 18, image 2 of 3 Google Pixel 9a Front Camera Removal, Remove the front camera: step 18, image 3 of 3
    • Use tweezers to grip the center of the front camera, between the press connector and the camera itself.
    • Flip the camera towards the right edge and gently peel it off the copper foil.
Finish Line
Spencer Day
156,599 Reputation
1,033 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,855 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 47
