Google Pixel 9a Wide Camera Replacement
  1. Google Pixel 9a Wide Camera Replacement, Safety precautions: step 1, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Safety precautions: step 1, image 2 of 2
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
  2. Google Pixel 9a Wide Camera Replacement, Remove the SIM card tray: step 2, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Remove the SIM card tray: step 2, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Remove the SIM card tray: step 2, image 3 of 3
    • Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of your phone until the tray ejects.
    • A small mic hole is next to the SIM tray—don't confuse the two!
    • Remove the SIM card tray.
  3. Google Pixel 9a Wide Camera Replacement, Heat the rear cover: step 3, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Heat the rear cover: step 3, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Heat the rear cover: step 3, image 3 of 3
    • Adhesive secures the rear cover to the frame. Heating the cover softens the adhesive, making it easier to separate.
    • Use a hair dryer to heat the entire rear cover.
    • Only heat your phone so it's just hot to the touch. Extreme heat can damage the rear cover, screen, or battery.
  4. Google Pixel 9a Wide Camera Replacement, Apply a suction handle: step 4, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Apply a suction handle: step 4, image 2 of 2
    • Apply a suction handle near the center of the rear cover's right edge, as close to the edge as possible.
  5. Google Pixel 9a Wide Camera Replacement, Insert an opening pick: step 5, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Insert an opening pick: step 5, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Insert an opening pick: step 5, image 3 of 3
    • Pull up on the suction handle with strong, steady force until a gap forms between the cover and frame.
    • Insert the tip of an opening pick into the gap.
  6. Google Pixel 9a Wide Camera Replacement, Adhesive information: step 6, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Adhesive information: step 6, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Adhesive information: step 6, image 3 of 3
    • The rear cover is secured with adhesive around the perimeter of the frame and near the cameras. Use this picture as a reference while you separate the adhesive.
    • When separating the left and right edge adhesive, don't insert your pick more than 3 mm to avoid damaging the wireless charging coil and its graphite film.
  7. Google Pixel 9a Wide Camera Replacement, Separate the rear cover adhesive: step 7, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Separate the rear cover adhesive: step 7, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Separate the rear cover adhesive: step 7, image 3 of 3
    • If you ever have trouble separating the adhesive, apply more heat and try again.
    • Slide the opening pick up the right edge, around the top right corner, and along the top edge to separate the adhesive securing the rear cover.
  8. Google Pixel 9a Wide Camera Replacement: step 8, image 1 of 3 Google Pixel 9a Wide Camera Replacement: step 8, image 2 of 3 Google Pixel 9a Wide Camera Replacement: step 8, image 3 of 3
    • Insert an opening pick in the initial gap you created near the center of the rear cover's right edge.
    • Slide the opening pick down the right edge, along the bottom edge, and up the left edge to separate the adhesive securing the cover.
  9. Google Pixel 9a Wide Camera Replacement, Separate the camera bezel adhesive: step 9, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Separate the camera bezel adhesive: step 9, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Separate the camera bezel adhesive: step 9, image 3 of 3
    • Insert the flat edge of an opening pick under the top of the rear cover's left edge, near the camera bezel.
    • Twist the pick and apply constant pressure to separate the adhesive around the camera bezel.
  10. Google Pixel 9a Wide Camera Replacement, Remove the rear cover: step 10, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Remove the rear cover: step 10, image 2 of 2
    • Remove the rear cover.
    • If you feel resistance, go back around the perimeter of the cover and use a pick to separate any remaining adhesive.
  11. Google Pixel 9a Wide Camera Replacement, Remove the camera bezel: step 11, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Remove the camera bezel: step 11, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Remove the camera bezel: step 11, image 3 of 3
    • If the camera bezel detached from the rear cover and stayed stuck to your phone, follow this step to remove it. Otherwise, skip this step.
    • Slide an opening pick under the camera bezel and pry up to remove it.
    • Only insert the pick a few millimeters under the bezel, or you risk damaging the cameras.
    • If you're having trouble, lightly heat the camera bezel.
  12. Google Pixel 9a Wide Camera Replacement, Remove the wireless charging assembly screws: step 12, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Remove the wireless charging assembly screws: step 12, image 2 of 2
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Use a Torx Plus 3IP screwdriver to remove the 16 screws securing the wireless charging assembly:
    • Thirteen 5.0 mm‑long screws
    • Three 2.2 mm‑long screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
  13. Google Pixel 9a Wide Camera Replacement, Unclip the wireless charging assembly: step 13, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Unclip the wireless charging assembly: step 13, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Unclip the wireless charging assembly: step 13, image 3 of 3
  14. Google Pixel 9a Wide Camera Replacement, Remove the wireless charging assembly: step 14, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Remove the wireless charging assembly: step 14, image 2 of 2
    • Remove the wireless charging assembly.
  15. Google Pixel 9a Wide Camera Replacement, Remove the connector cover screw: step 15, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Remove the connector cover screw: step 15, image 2 of 2
    • Be careful not to damage the battery with your tools while disconnecting it.
    • Use a Torx Plus 3IP screwdriver to remove the 1.7 mm‑long screw securing the battery connector cover.
  16. Google Pixel 9a Wide Camera Replacement, Remove the battery connector cover: step 16, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Remove the battery connector cover: step 16, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Remove the battery connector cover: step 16, image 3 of 3
    • Use tweezers to lift and remove the battery connector cover.
  17. Google Pixel 9a Wide Camera Replacement, Disconnect the battery: step 17, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Disconnect the battery: step 17, image 2 of 2
    • Use a spudger to pry up and disconnect the battery cable press connector.
  18. Google Pixel 9a Wide Camera Replacement, Remove the logic board screws: step 18, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Remove the logic board screws: step 18, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Remove the logic board screws: step 18, image 3 of 3
    • Use a 3IP Torx Plus screwdriver to remove the two 2.8 mm‑long screws securing the logic board.
  19. Google Pixel 9a Wide Camera Replacement, Lift the logic board: step 19, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Lift the logic board: step 19, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Lift the logic board: step 19, image 3 of 3
    • Be careful not to smudge the cameras when handling the logic board.
    • Before trying to remove the logic board, double‑check that you removed the SIM card tray.
    • Insert the point of a spudger under the screw hole near the cameras and lift the board until you can grip it with your fingers.
  20. Google Pixel 9a Wide Camera Replacement, Free the bottom edge of the logic board: step 20, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Free the bottom edge of the logic board: step 20, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Free the bottom edge of the logic board: step 20, image 3 of 3
    • Don't try to fully remove the logic board yet, as it's still connected to the frame by the screen cable.
    • Grip the skinny section of the board with your fingers and lift until the clip near the bottom edge of the battery releases.
    • Pull the top edge of the board to the right of the frame until the charge port slides fully out of its recess.
  21. Google Pixel 9a Wide Camera Replacement, Lay the logic board down: step 21, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Lay the logic board down: step 21, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Lay the logic board down: step 21, image 3 of 3
    • The logic board may fall out of place during this step. Hold it steady, but don't grip any of the camera lenses or connectors.
    • Apply a suction handle to the screen and use it to prop up your phone.
    • Gently lay the logic board down flat against your work surface, being careful not to strain the screen cable.
  22. Google Pixel 9a Wide Camera Replacement, Remove the logic board connector cover: step 22, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Remove the logic board connector cover: step 22, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to remove the 1.7 mm‑long screw securing the screen cable cover.
  23. Google Pixel 9a Wide Camera Replacement, Remove the connector cover: step 23, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Remove the connector cover: step 23, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Remove the connector cover: step 23, image 3 of 3
    • Use tweezers to lift and remove the screen cable cover.
  24. Google Pixel 9a Wide Camera Replacement, Disconnect the logic board: step 24, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Disconnect the logic board: step 24, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the screen cable press connector.
  25. Google Pixel 9a Wide Camera Replacement, Remove the logic board: step 25, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Remove the logic board: step 25, image 2 of 2
    • Slide the logic board away from the frame and remove it.
  26. Google Pixel 9a Wide Camera Replacement, Remove the wide camera: step 26, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Remove the wide camera: step 26, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Remove the wide camera: step 26, image 3 of 3
    • Hold the logic board slightly above your work surface while working on the camera—don't press the board against your work surface, or you may damage fragile components.
    • Use the flat end of a spudger to pry up and disconnect the wide camera press connector.
    • Be careful not to damage the four spring contacts next to the connector.
    • Remove the wide camera.
  27. Google Pixel 9a Wide Camera Replacement, Install the wide camera: step 27, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Install the wide camera: step 27, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Install the wide camera: step 27, image 3 of 3
    • Leave any lens caps or liners on the camera for now—they'll protect the lens during reassembly. You'll remove them before installing the back cover.
    • Put the wide camera into place on the logic board, being careful not to smudge the lens.
    • Align the press connector over its socket and press down with your fingertip—first on one of the short sides, then the other—until it clicks into place.
  28. Google Pixel 9a Wide Camera Replacement, Check the thermal pads: step 28, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Check the thermal pads: step 28, image 2 of 2
    • Check the condition of the logic board thermal pads—they'll either be on the bottom of the board or stuck to the corresponding spot on the frame.
    • If the pads are ripped, torn, or otherwise damaged, follow the next five steps to replace them. If they aren't, skip ahead five steps.
  29. Google Pixel 9a Wide Camera Replacement, Remove the thermal pads: step 29, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Remove the thermal pads: step 29, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Remove the thermal pads: step 29, image 3 of 3
    • Use the flat end of a spudger to scrape up and remove the damaged thermal pads.
  30. Google Pixel 9a Wide Camera Replacement: step 30, image 1 of 1
    • Use high‑concentration (>90%) isopropyl alcohol and a coffee filter to clean up and remove any residue where the thermal pads were.
  31. Google Pixel 9a Wide Camera Replacement, Apply the thermal pads: step 31, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Apply the thermal pads: step 31, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Apply the thermal pads: step 31, image 3 of 3
    • The thermal pads are very delicate and can easily be misaligned when placing them and removing liners. Take your time when applying them—good placement will ensure proper heat dissipation.
    • Remove the textured liner from the smaller thermal pad.
    • Carefully place the pad onto the board.
    • Use this photo as a reference to help align the pad.
    • Use the flat end of a spudger or your finger to press down lightly on the entire surface of the thermal pad, securing it in place without deforming it.
  32. Google Pixel 9a Wide Camera Replacement: step 32, image 1 of 2 Google Pixel 9a Wide Camera Replacement: step 32, image 2 of 2
    • Slowly lift and remove the remaining liners from the top of the thermal pad.
    • If the thermal pad start to lift up with the liners, lay it back down and press again to secure it.
  33. Google Pixel 9a Wide Camera Replacement: step 33, image 1 of 3 Google Pixel 9a Wide Camera Replacement: step 33, image 2 of 3 Google Pixel 9a Wide Camera Replacement: step 33, image 3 of 3
    • Repeat the previous two steps to apply the remaining, larger thermal pad.
  34. Google Pixel 9a Wide Camera Replacement, Slide the logic board into place: step 34, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Slide the logic board into place: step 34, image 2 of 2
    • If it isn't already, prop your phone up with the suction handle.
    • Slide the logic board up against the frame so the screen cable is near its connector.
  35. Google Pixel 9a Wide Camera Replacement, Connect the screen cable: step 35, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Connect the screen cable: step 35, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Connect the screen cable: step 35, image 3 of 3
    • Align the screen cable press connector over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place.
  36. Google Pixel 9a Wide Camera Replacement, Install the screen cable cover: step 36, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Install the screen cable cover: step 36, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Install the screen cable cover: step 36, image 3 of 3
    • Use tweezers to hook the bottom edge of the screen cable cover into place, then lay the cover down flat.
  37. Google Pixel 9a Wide Camera Replacement: step 37, image 1 of 2 Google Pixel 9a Wide Camera Replacement: step 37, image 2 of 2
    • Use a 3IP Torx Plus screwdriver to install the 1.7 mm‑long screw securing the screen cable cover.
  38. Google Pixel 9a Wide Camera Replacement, Flip up the logic board: step 38, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Flip up the logic board: step 38, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Flip up the logic board: step 38, image 3 of 3
    • Flip the logic board up so it's gently resting in its recess in the frame.
    • Remove the suction cup and lay your phone screen-side down.
  39. Google Pixel 9a Wide Camera Replacement, Put the logic board into place: step 39, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Put the logic board into place: step 39, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Put the logic board into place: step 39, image 3 of 3
    • When inserting the logic board, make sure the battery cable doesn't get caught underneath. You may need to gently bend it out of the way.
    • Push the logic board toward the bottom of the frame and press the charging port down until it snaps into its cutout.
    • Press down on the center of the logic board's bottom edge until the clip near the battery engages.
  40. Google Pixel 9a Wide Camera Replacement: step 40, image 1 of 1
    • Push down on the top edge of the logic board so it goes into its recess. Make sure the cameras are sitting flush and not at odd angles.
  41. Google Pixel 9a Wide Camera Replacement, Install the logic board screws: step 41, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Install the logic board screws: step 41, image 2 of 2
    • Use a 3IP Torx Plus screwdriver to install the two 2.8 mm‑long screws securing the logic board.
    • Make sure the logic board lays flat, with nothing caught underneath, before tightening these screws.
  42. Google Pixel 9a Wide Camera Replacement, Remove the old adhesive: step 42, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Remove the old adhesive: step 42, image 2 of 2
    • Use a spudger to scrape up and remove the six small pieces of adhesive around the rear cameras.
    • Use high‑concentration (>90%) isopropyl alcohol and a lint‑free cloth (or coffee filter) to clean up and remove any residue from the adhesives that were removed.
  43. Google Pixel 9a Wide Camera Replacement, Apply the adhesive: step 43, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Apply the adhesive: step 43, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Apply the adhesive: step 43, image 3 of 3
    • Remove the larger, clear liner from the inner housing adhesive and lay it in place around the camera holes.
    • Use the cutouts for the small silver pads to help align the adhesive.
    • Use the flat end of a spudger to firmly push down on each piece of adhesive, securing them in place.
    • Remove the colored liner using the pull tab on the top edge.
    • If the adhesive starts to pull up with the liner, lay it back in place and use your spudger to secure it again.
  44. Google Pixel 9a Wide Camera Replacement, Secure the adhesive: step 44, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Secure the adhesive: step 44, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Secure the adhesive: step 44, image 3 of 3
    • Use a spudger to firmly press down on each of the six pieces of inner housing adhesive to secure them.
    • These pieces of adhesive can easily be pulled up when removing the final liners, so make sure they're firmly in place.
  45. Google Pixel 9a Wide Camera Replacement, Connect the battery press connector: step 45, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Connect the battery press connector: step 45, image 2 of 2
    • Use your finger to align the battery press connector over its socket and press down to connect it.
    • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  46. Google Pixel 9a Wide Camera Replacement, Install the battery connector cover: step 46, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Install the battery connector cover: step 46, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Install the battery connector cover: step 46, image 3 of 3
    • Use tweezers to hook the left edge of the battery connector cover into place, then lay the cover down flat.
  47. Google Pixel 9a Wide Camera Replacement: step 47, image 1 of 2 Google Pixel 9a Wide Camera Replacement: step 47, image 2 of 2
    • Use a 3IP Torx Plus screwdriver to install the 1.7 mm‑long screw securing the battery connector cover.
  48. Google Pixel 9a Wide Camera Replacement, Install the wireless charging assembly: step 48, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Install the wireless charging assembly: step 48, image 2 of 2
    • Place the wireless charging assembly onto the frame.
  49. Google Pixel 9a Wide Camera Replacement: step 49, image 1 of 3 Google Pixel 9a Wide Camera Replacement: step 49, image 2 of 3 Google Pixel 9a Wide Camera Replacement: step 49, image 3 of 3
    • Use your fingers to firmly press around the perimeter of the wireless charging assembly to re‑engage all of its clips.
  50. Google Pixel 9a Wide Camera Replacement, Install the wireless charging assembly screws: step 50, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Install the wireless charging assembly screws: step 50, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to install the 16 screws securing the wireless charging assembly:
  51. Google Pixel 9a Wide Camera Replacement, Remove the old rear cover adhesive: step 51, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Remove the old rear cover adhesive: step 51, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Remove the old rear cover adhesive: step 51, image 3 of 3
    • Take your time during the next two steps. A clean frame allows replacement adhesive to lay evenly, ensuring a better bond.
    • Use a spudger and tweezers to scrape up and remove all the old rear cover adhesive from the perimeter of your phone.
    • If you scrape up a piece big enough to grip with your fingers, you can pull long sections of the adhesive up. Pull slowly and straight in the opposite direction of the adhesive.
  52. Google Pixel 9a Wide Camera Replacement, Clean the frame: step 52, image 1 of 1
    • Using some high-concentration (>90%) isopropyl alcohol and a lint‑free cloth (or coffee filter), clean the areas of the frame where the adhesive was.
  53. Google Pixel 9a Wide Camera Replacement, Find the adhesive orientation: step 53, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Find the adhesive orientation: step 53, image 2 of 2
    • Before applying the rear cover adhesive, make sure you know how it will sit on the frame. If you apply the adhesive incorrectly, you'll need to restart with new adhesive.
    • Hold the adhesive above the frame to find its orientation. Use the camera cutout in the liner to help visualize how it will lay on the frame.
  54. Google Pixel 9a Wide Camera Replacement, Peel the liner halfway down: step 54, image 1 of 1
    • Peel down the top half of the large, clear liner to expose the adhesive—don't fully remove the liner yet.
  55. Google Pixel 9a Wide Camera Replacement, Apply the adhesive: step 55, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Apply the adhesive: step 55, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Apply the adhesive: step 55, image 3 of 3
    • Take your time aligning the adhesive with the frame—it's very sticky and can't be moved once you apply it.
    • With the larger, clear liner folded towards the bottom of the phone, lay the exposed top edge of the adhesive onto the frame.
    • Use the lip of the frame to help align the adhesive.
    • Once the top edge is properly aligned, gently press down on the top corners with your fingers to secure the adhesive.
  56. Google Pixel 9a Wide Camera Replacement: step 56, image 1 of 3 Google Pixel 9a Wide Camera Replacement: step 56, image 2 of 3 Google Pixel 9a Wide Camera Replacement: step 56, image 3 of 3
    • Slowly lay the rest of the adhesive onto the frame, pressing it into place and peeling away the larger liner as you go.
  57. Google Pixel 9a Wide Camera Replacement, Remove the top liner: step 57, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Remove the top liner: step 57, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Remove the top liner: step 57, image 3 of 3
    • Use the pull tab to remove the large, colored liner.
  58. Google Pixel 9a Wide Camera Replacement, Secure the adhesive: step 58, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Secure the adhesive: step 58, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Secure the adhesive: step 58, image 3 of 3
    • Use a spudger to press down firmly on the adhesive around the perimeter of your phone to secure it to the frame.
  59. Google Pixel 9a Wide Camera Replacement, Remove the old camera bezel adhesive: step 59, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Remove the old camera bezel adhesive: step 59, image 2 of 2
    • If the camera bezel detached when removing the rear cover, follow the next five steps to install it. Otherwise, skip down five steps.
    • Use a spudger to scrape up and remove any of the old adhesive from the camera bezel and its corresponding spot on the rear cover.
  60. Google Pixel 9a Wide Camera Replacement, Remove the adhesive residue: step 60, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Remove the adhesive residue: step 60, image 2 of 2
    • Use high-concentration (>90%) isopropyl alcohol and a lint‑free cloth (or coffee filter) to clean up and remove any adhesive residue from the camera bezel and its corresponding spot on the rear cover.
  61. Google Pixel 9a Wide Camera Replacement, Apply the adhesive: step 61, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Apply the adhesive: step 61, image 2 of 2
    • Remove the large, clear liner from the camera bezel adhesive.
    • Put the adhesive over the top of the camera bezel and set it in place.
  62. Google Pixel 9a Wide Camera Replacement: step 62, image 1 of 3 Google Pixel 9a Wide Camera Replacement: step 62, image 2 of 3 Google Pixel 9a Wide Camera Replacement: step 62, image 3 of 3
    • Use a spudger to firmly press around the perimeter of the camera bezel to secure the adhesive.
    • Remove the second, colored liner from the camera bezel adhesive.
  63. Google Pixel 9a Wide Camera Replacement, Install the camera bezel: step 63, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Install the camera bezel: step 63, image 2 of 2
    • Align the camera bezel such that the square foam is closest to the edge.
    • Use your fingers to press the camera bezel into place on the rear cover, squeezing firmly around the perimeter to secure it with the adhesive.
  64. Google Pixel 9a Wide Camera Replacement, Remove the old rear cover adhesive: step 64, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Remove the old rear cover adhesive: step 64, image 2 of 2
    • Use the flat end of a spudger to scrape up and remove any all the old adhesive that stayed on the back cover, including the five pieces of small, oval‑shaped adhesive.
    • If you don't see all the oval adhesives, some might've stuck to the phone frame.
  65. Google Pixel 9a Wide Camera Replacement: step 65, image 1 of 1
    • Use high‑concentration (>90%) isopropyl alcohol and a lint‑free cloth (or coffee filter) to clean up and remove any residue from the adhesives you removed.
  66. Google Pixel 9a Wide Camera Replacement, Apply the adhesive: step 66, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Apply the adhesive: step 66, image 2 of 2
    • Remove the larger, clear liner from the back cover inner adhesive.
    • Lay the adhesive onto the bottom of the back cover, making sure the cutout goes around the camera bezel.
  67. Google Pixel 9a Wide Camera Replacement, Secure the adhesive: step 67, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Secure the adhesive: step 67, image 2 of 2
    • Use your fingers or a spudger to firmly push down on the five small adhesives to secure them to the back cover.
    • Slowly peel up and remove the remaining liner.
    • If the adhesives start to peel up with the liner, lay it back down and use your spudger to secure the adhesive again.
  68. Google Pixel 9a Wide Camera Replacement, Remove the lens cap: step 68, image 1 of 2 Google Pixel 9a Wide Camera Replacement, Remove the lens cap: step 68, image 2 of 2
    • Remove any lens cap or liners from the wide camera.
  69. Google Pixel 9a Wide Camera Replacement, Remove the remaining liners: step 69, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Remove the remaining liners: step 69, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Remove the remaining liners: step 69, image 3 of 3
    • Use the point of a spudger to lift and remove the plastic liners from the adhesive around the rear cameras.
  70. Google Pixel 9a Wide Camera Replacement: step 70, image 1 of 2 Google Pixel 9a Wide Camera Replacement: step 70, image 2 of 2
    • Use the pull tabs to remove the final liner from the rear cover adhesive.
  71. Google Pixel 9a Wide Camera Replacement, Install the rear cover: step 71, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Install the rear cover: step 71, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Install the rear cover: step 71, image 3 of 3
    • Align the rear cover over the frame and press it into place.
  72. Google Pixel 9a Wide Camera Replacement: step 72, image 1 of 3 Google Pixel 9a Wide Camera Replacement: step 72, image 2 of 3 Google Pixel 9a Wide Camera Replacement: step 72, image 3 of 3
  73. Google Pixel 9a Wide Camera Replacement, Install the SIM card tray: step 73, image 1 of 3 Google Pixel 9a Wide Camera Replacement, Install the SIM card tray: step 73, image 2 of 3 Google Pixel 9a Wide Camera Replacement, Install the SIM card tray: step 73, image 3 of 3
    • Push the SIM card tray completely into its slot on the bottom edge of your phone.
Congratulations on completing your repair!
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Spencer Day
156,100 Reputation
1,033 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,828 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 35
All Time: 342
