Google Pixel C Screen Replacement
  1. Google Pixel C Screen Replacement, Screen: step 1, image 1 of 1
    • Ensure that the device is completely powered down before beginning to take it apart
    • Use a heat gun to melt the adhesive that holds the screen to the device
    • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
    • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
  2. Google Pixel C Screen Replacement: step 2, image 1 of 2 Google Pixel C Screen Replacement: step 2, image 2 of 2
    • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
    • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
    • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
    • Reattaching the screen will require adhesive to ensure that it stays in place.
  3. Google Pixel C Screen Replacement: step 3, image 1 of 2 Google Pixel C Screen Replacement: step 3, image 2 of 2
    • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
  4. Google Pixel C Screen Replacement: step 4, image 1 of 2 Google Pixel C Screen Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Follow the same removal procedure to detach the wide gold cable.
    • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
    • This device is missing a battery, so the device that you are working on may appear slightly different inside.
9 other people completed this guide.
Deborah Iwakiri
522 Reputation
2 Guides authored
Cal Poly, Team S21-G4, Livingston Spring 2017 Member of Cal Poly, Team S21-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G4
4 Members
11 Guides authored
28 Guide Comments
Where can a replacement screen be located?
Ronnie Williams - Reply
Where can i buy a spare screen for this tablet?
Luigi Abbinante - Reply
Yes, I have to buy the screen too, but where??
Кирилл Кнышев - Reply
All very nice but unfortunately useless without knowing where to get the parts :(
Lorenzo Braschi - Reply
Ciao Lorenzo, sei poi riuscito a trovare il ricambio?
Luigi Abbinante -
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 81
All Time: 18,793
