Google Pixel Slate Motherboard Replacement
  1. Google Pixel Slate Motherboard Replacement, Screen: step 1, image 1 of 3 Google Pixel Slate Motherboard Replacement, Screen: step 1, image 2 of 3 Google Pixel Slate Motherboard Replacement, Screen: step 1, image 3 of 3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Motherboard Replacement: step 2, image 1 of 3 Google Pixel Slate Motherboard Replacement: step 2, image 2 of 3 Google Pixel Slate Motherboard Replacement: step 2, image 3 of 3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Motherboard Replacement, Motherboard: step 3, image 1 of 3 Google Pixel Slate Motherboard Replacement, Motherboard: step 3, image 2 of 3 Google Pixel Slate Motherboard Replacement, Motherboard: step 3, image 3 of 3
    • Once the screen is removed, remove the two black, adhesive strips.
  4. Google Pixel Slate Motherboard Replacement: step 4, image 1 of 3 Google Pixel Slate Motherboard Replacement: step 4, image 2 of 3 Google Pixel Slate Motherboard Replacement: step 4, image 3 of 3
    • Use a T3 Torx screwdriver to remove the two black screws that are holding down the copper strip.
  5. Google Pixel Slate Motherboard Replacement: step 5, image 1 of 3 Google Pixel Slate Motherboard Replacement: step 5, image 2 of 3 Google Pixel Slate Motherboard Replacement: step 5, image 3 of 3
    • Use the T3 Torx screwdriver to remove the seven 3mm screws.
    • Use a T2 Torx screwdriver to remove the pink 2mm screw closest to the edge.
    • There is a total of four blue 3mm screws, two black 3mm screws, one pink 3mm screw, and one pink 2mm screw holding down the plate.
  6. Google Pixel Slate Motherboard Replacement: step 6, image 1 of 2 Google Pixel Slate Motherboard Replacement: step 6, image 2 of 2
    • Lift and remove the metal plate.
  7. Google Pixel Slate Motherboard Replacement: step 7, image 1 of 3 Google Pixel Slate Motherboard Replacement: step 7, image 2 of 3 Google Pixel Slate Motherboard Replacement: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the two speaker plugs, one battery plug, and disconnect the four flat wires from the motherboard.
    • Nylon Tipped Tweezers may be necessary to remove the wires effectively.
  8. Google Pixel Slate Motherboard Replacement: step 8, image 1 of 3 Google Pixel Slate Motherboard Replacement: step 8, image 2 of 3 Google Pixel Slate Motherboard Replacement: step 8, image 3 of 3
    • Use a T3 Torx screwdriver to remove the two silver screws.
    • Remove the 4 exposed washers from the motherboard and put aside.
  9. Google Pixel Slate Motherboard Replacement: step 9, image 1 of 3 Google Pixel Slate Motherboard Replacement: step 9, image 2 of 3 Google Pixel Slate Motherboard Replacement: step 9, image 3 of 3
    • Use the iFixit opening tool to remove the motherboard from the device.
3 other people completed this guide.
Spencer Alonge
648 Reputation
5 Guides authored
Cal Poly, Team S2-G5, Maness Spring 2019 Member of Cal Poly, Team S2-G5, Maness Spring 2019
CPSU-MANESS-S19S2G5
4 Members
5 Guides authored
One Comment
Very helpful, nice and clear steps.
Eddie Lundberg - Reply
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 64
All Time: 3,389
