Google Pixel Slate Rear-Facing Camera Replacement
  1. Google Pixel Slate Rear-Facing Camera Replacement, Screen: step 1, image 1 of 3 Google Pixel Slate Rear-Facing Camera Replacement, Screen: step 1, image 2 of 3 Google Pixel Slate Rear-Facing Camera Replacement, Screen: step 1, image 3 of 3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Rear-Facing Camera Replacement: step 2, image 1 of 3 Google Pixel Slate Rear-Facing Camera Replacement: step 2, image 2 of 3 Google Pixel Slate Rear-Facing Camera Replacement: step 2, image 3 of 3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Rear-Facing Camera Replacement, Rear-Facing Camera: step 3, image 1 of 3 Google Pixel Slate Rear-Facing Camera Replacement, Rear-Facing Camera: step 3, image 2 of 3 Google Pixel Slate Rear-Facing Camera Replacement, Rear-Facing Camera: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Use a T2 Torx screwdriver to remove the two black 2mm screws holding down the square plate.
    • Use the Nylon Tipped Tweezers to lift the metal plate.
  4. Google Pixel Slate Rear-Facing Camera Replacement: step 4, image 1 of 3 Google Pixel Slate Rear-Facing Camera Replacement: step 4, image 2 of 3 Google Pixel Slate Rear-Facing Camera Replacement: step 4, image 3 of 3
    • Use a T3 Torx screwdriver to remove the two yellow and grey 3mm screws from the L-shaped plate.
    • Use the Nylon Tipped Tweezers to lift the plate from the device.
  5. Google Pixel Slate Rear-Facing Camera Replacement: step 5, image 1 of 2 Google Pixel Slate Rear-Facing Camera Replacement: step 5, image 2 of 2
    • Gently pull upwards to remove the camera.
Spencer Alonge
648 Reputation
5 Guides authored
Cal Poly, Team S2-G5, Maness Spring 2019 Member of Cal Poly, Team S2-G5, Maness Spring 2019
CPSU-MANESS-S19S2G5
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 7
All Time: 549
