Google Pixel Slate Speaker Replacement
  1. Google Pixel Slate Speaker Replacement, Screen: step 1, image 1 of 3 Google Pixel Slate Speaker Replacement, Screen: step 1, image 2 of 3 Google Pixel Slate Speaker Replacement, Screen: step 1, image 3 of 3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Speaker Replacement: step 2, image 1 of 3 Google Pixel Slate Speaker Replacement: step 2, image 2 of 3 Google Pixel Slate Speaker Replacement: step 2, image 3 of 3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Speaker Replacement, Speaker: step 3, image 1 of 3 Google Pixel Slate Speaker Replacement, Speaker: step 3, image 2 of 3 Google Pixel Slate Speaker Replacement, Speaker: step 3, image 3 of 3
    • There are two speakers, one on each side of the Google Pixel Slate. This guide works for either one.
    • Use the T2 Torx screwdriver to remove the yellow 2mm screw from the thin metal plate.
    • Use the T3 Torx screwdriver to remove the pink 3mm screw from the thin metal plate.
    • Remove the thin metal plate from the device.
  4. Google Pixel Slate Speaker Replacement: step 4, image 1 of 1
    • Use the T2 Torx screwdriver to remove the two black 2mm screws from the speaker.
  5. Google Pixel Slate Speaker Replacement: step 5, image 1 of 2 Google Pixel Slate Speaker Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Use the Nylon-Tipped Tweezers to remove the black plug.
    • There is a red and a black wire connected to the black plug.
    • Pull the black plug in an upwards direction.
    • Be sure to gently remove plug, as using too much force can damage the connecting wires.
  6. Google Pixel Slate Speaker Replacement: step 6, image 1 of 2 Google Pixel Slate Speaker Replacement: step 6, image 2 of 2
    • Use the Nylon-Tipped Tweezers to disconnect the black tape-like plug connected to the speaker.
  7. Google Pixel Slate Speaker Replacement: step 7, image 1 of 2 Google Pixel Slate Speaker Replacement: step 7, image 2 of 2
    • Detach the speaker wire from the motherboard.
    • Remove the adhesive strips that hold down the speaker wire.
  8. Google Pixel Slate Speaker Replacement: step 8, image 1 of 3 Google Pixel Slate Speaker Replacement: step 8, image 2 of 3 Google Pixel Slate Speaker Replacement: step 8, image 3 of 3
    • Use the T2 Torx screwdriver to remove the 2mm black screw from the brass plate.
    • Pull back the brass plate.
  9. Google Pixel Slate Speaker Replacement: step 9, image 1 of 1
    • You can now remove the speaker from the device.
3 other people completed this guide.
Spencer Alonge
648 Reputation
5 Guides authored
Cal Poly, Team S2-G5, Maness Spring 2019 Member of Cal Poly, Team S2-G5, Maness Spring 2019
CPSU-MANESS-S19S2G5
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 918
