Google Pixelbook Go Back Panel Replacement
  1. Google Pixelbook Go Back Panel Replacement, Back Panel: step 1, image 1 of 2 Google Pixelbook Go Back Panel Replacement, Back Panel: step 1, image 2 of 2
    • Flip the device so that the back is facing up.
    • Peel the rubber stoppers off the top and bottom of the device.
  2. Google Pixelbook Go Back Panel Replacement: step 2, image 1 of 2 Google Pixelbook Go Back Panel Replacement: step 2, image 2 of 2
    • Remove ten 3 mm screws from around the edge of the back panel using a T5 Torx screwdriver.
  3. Google Pixelbook Go Back Panel Replacement: step 3, image 1 of 3 Google Pixelbook Go Back Panel Replacement: step 3, image 2 of 3 Google Pixelbook Go Back Panel Replacement: step 3, image 3 of 3
    • Use an iFixit opening tool to pry up the back panel cover.
    • There is an orange ribbon cable that connects the cover to the base, so don't separate the two pieces completely.
    • Remove the single 2 mm screw using a Torx T3 screwdriver.
    • Disconnect the orange cable from the base of the device.
  4. Google Pixelbook Go Back Panel Replacement: step 4, image 1 of 1
    • Insert wisdom here.
Kristen Gismondi
85,242 Reputation
215 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,077 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 27
All Time: 485
