Google Stadia Controller Opening Procedure
  1. Google Stadia Controller Opening Procedure, Loosen the screw cover adhesive: step 1, image 1 of 1
    • Apply a heated iOpener to the rear side of the Stadia controller where the screw cover is located to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
  2. Google Stadia Controller Opening Procedure, Insert an opening pick: step 2, image 1 of 2 Google Stadia Controller Opening Procedure, Insert an opening pick: step 2, image 2 of 2
    • Insert the tip of an opening pick into the gap between the plastic screw cover and the rear case of the controller.
  3. Google Stadia Controller Opening Procedure, Remove the screw cover: step 3, image 1 of 3 Google Stadia Controller Opening Procedure, Remove the screw cover: step 3, image 2 of 3 Google Stadia Controller Opening Procedure, Remove the screw cover: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Slide the opening pick along the screw cover to slice the adhesive.
    • Use a pair of tweezers or your fingers to remove the screw cover.
    • You might want to replace the screw cover adhesive during reassembly. Apply a bit of high-concentration isopropyl alcohol (>90%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on the rear cover of the controller before installing new adhesive.
  4. Google Stadia Controller Opening Procedure, Unfasten the rear case screw: step 4, image 1 of 1
    • Use a Torx T8 screwdriver to remove the 9.6 mm-long screw securing the rear case.
  5. Google Stadia Controller Opening Procedure, Disassembly information: step 5, image 1 of 2 Google Stadia Controller Opening Procedure, Disassembly information: step 5, image 2 of 2
    • The front cover assembly of the Stadia controller is held in place by various tight plastic clamps. They are very hard to open and snap back in place easily.
    • The opening procedure requires some force, however, try to avoid damaging your controller case along the way.
  6. Google Stadia Controller Opening Procedure, Pry open the stadia controller: step 6, image 1 of 3 Google Stadia Controller Opening Procedure, Pry open the stadia controller: step 6, image 2 of 3 Google Stadia Controller Opening Procedure, Pry open the stadia controller: step 6, image 3 of 3
    • Insert a Jimmy into the gap between the front and back cover assembly at the inside of the left controller handle.
    • To make sure you insert the Jimmy at the correct position where the clamps are located, you can use this photo.
    • Tilt the Jimmy upwards and push it into the gap between the covers at the same time to pry open the plastic clamp. You should hear a clack noise once the clamp pops open.
    • Once the clamp is completely open, the gap between the two controller covers should be about 2-3 mm wide.
  7. Google Stadia Controller Opening Procedure, Insert an opening pick: step 7, image 1 of 2 Google Stadia Controller Opening Procedure, Insert an opening pick: step 7, image 2 of 2
    • Insert an opening pick in a steep angle into the gap you created to prevent the first clamp from popping back into its closed position.
  8. Google Stadia Controller Opening Procedure, Pry open the Stadia controller: step 8, image 1 of 3 Google Stadia Controller Opening Procedure, Pry open the Stadia controller: step 8, image 2 of 3 Google Stadia Controller Opening Procedure, Pry open the Stadia controller: step 8, image 3 of 3
    • Insert a Jimmy into the gap between the front and back cover assembly at the outside of the left bottom end of the controller handle.
    • Repeat the previous opening procedure to open the three plastic clamps at the outside of the left controller handle.
  9. Google Stadia Controller Opening Procedure: step 9, image 1 of 3 Google Stadia Controller Opening Procedure: step 9, image 2 of 3 Google Stadia Controller Opening Procedure: step 9, image 3 of 3
    • Insert a Jimmy into the gap between the front and back cover assembly between the left shoulder button and the charging port at the top edge of the Stadia controller.
    • Repeat the previous procedure at the clamp between the right shoulder button and the charging port.
  10. Google Stadia Controller Opening Procedure: step 10, image 1 of 3 Google Stadia Controller Opening Procedure: step 10, image 2 of 3 Google Stadia Controller Opening Procedure: step 10, image 3 of 3
    • Insert a Jimmy into the gap between the front and back cover assembly at the right edge of the right controller handle.
    • Repeat the previous opening procedure to open the three plastic clamps at the outside of the right controller handle.
  11. Google Stadia Controller Opening Procedure: step 11, image 1 of 2 Google Stadia Controller Opening Procedure: step 11, image 2 of 2
    • Insert a Jimmy into the gap between the front and back cover assembly at the inside of the right controller handle.
    • Repeat the previous opening procedure to open plastic clamps at the inside of the left controller handle.
  12. Google Stadia Controller Opening Procedure: step 12, image 1 of 3 Google Stadia Controller Opening Procedure: step 12, image 2 of 3 Google Stadia Controller Opening Procedure: step 12, image 3 of 3
    • Insert a Jimmy into the gap between the front and back cover assembly at the bottom edge of the Stadia controller right to the headphone jack.
    • Repeat the previous procedure at the clamp left to the headphone jack.
    • Do not try to remove the front cover assembly all the way yet. It's still connected to the rear cover assembly.
  13. Google Stadia Controller Opening Procedure, Unfold the front cover assembly: step 13, image 1 of 3 Google Stadia Controller Opening Procedure, Unfold the front cover assembly: step 13, image 2 of 3 Google Stadia Controller Opening Procedure, Unfold the front cover assembly: step 13, image 3 of 3
    • Avoid straining the front cover assembly cable during this step.
    • Carefully lift the front cover assembly and fold it to the left side of the Google Stadia controller.
6 other people completed this guide.
Dominik Schnabelrauch
249,374 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,927 Guides authored
1 Guide Comment
Screwdriver in step 4 should actually be a T9 torx, although T8 also kind of works.
Elbert - Reply
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 217
All Time: 8,706
