Google Stadia Controller Shoulder Buttons Replacement
  1. Google Stadia Controller Shoulder Buttons Replacement, Loosen the screw cover adhesive: step 1, image 1 of 1
    • Apply a heated iOpener to the rear side of the Stadia controller where the screw cover is located to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
  2. Google Stadia Controller Shoulder Buttons Replacement, Insert an opening pick: step 2, image 1 of 2 Google Stadia Controller Shoulder Buttons Replacement, Insert an opening pick: step 2, image 2 of 2
    • Insert the tip of an opening pick into the gap between the plastic screw cover and the rear case of the controller.
  3. Google Stadia Controller Shoulder Buttons Replacement, Remove the screw cover: step 3, image 1 of 3 Google Stadia Controller Shoulder Buttons Replacement, Remove the screw cover: step 3, image 2 of 3 Google Stadia Controller Shoulder Buttons Replacement, Remove the screw cover: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Slide the opening pick along the screw cover to slice the adhesive.
    • Use a pair of tweezers or your fingers to remove the screw cover.
    • You might want to replace the screw cover adhesive during reassembly. Apply a bit of high-concentration isopropyl alcohol (>90%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on the rear cover of the controller before installing new adhesive.
  4. Google Stadia Controller Shoulder Buttons Replacement, Unfasten the rear case screw: step 4, image 1 of 1
    • Use a Torx T8 screwdriver to remove the 9.6 mm-long screw securing the rear case.
  5. Google Stadia Controller Shoulder Buttons Replacement, Disassembly information: step 5, image 1 of 2 Google Stadia Controller Shoulder Buttons Replacement, Disassembly information: step 5, image 2 of 2
    • The front cover assembly of the Stadia controller is held in place by various tight plastic clamps. They are very hard to open and snap back in place easily.
    • The opening procedure requires some force, however, try to avoid damaging your controller case along the way.
  6. Google Stadia Controller Shoulder Buttons Replacement, Pry open the stadia controller: step 6, image 1 of 3 Google Stadia Controller Shoulder Buttons Replacement, Pry open the stadia controller: step 6, image 2 of 3 Google Stadia Controller Shoulder Buttons Replacement, Pry open the stadia controller: step 6, image 3 of 3
    • Insert a Jimmy into the gap between the front and back cover assembly at the inside of the left controller handle.
    • To make sure you insert the Jimmy at the correct position where the clamps are located, you can use this photo.
    • Tilt the Jimmy upwards and push it into the gap between the covers at the same time to pry open the plastic clamp. You should hear a clack noise once the clamp pops open.
    • Once the clamp is completely open, the gap between the two controller covers should be about 2-3 mm wide.
  7. Google Stadia Controller Shoulder Buttons Replacement, Insert an opening pick: step 7, image 1 of 2 Google Stadia Controller Shoulder Buttons Replacement, Insert an opening pick: step 7, image 2 of 2
    • Insert an opening pick in a steep angle into the gap you created to prevent the first clamp from popping back into its closed position.
  8. Google Stadia Controller Shoulder Buttons Replacement, Pry open the Stadia controller: step 8, image 1 of 3 Google Stadia Controller Shoulder Buttons Replacement, Pry open the Stadia controller: step 8, image 2 of 3 Google Stadia Controller Shoulder Buttons Replacement, Pry open the Stadia controller: step 8, image 3 of 3
    • Insert a Jimmy into the gap between the front and back cover assembly at the outside of the left bottom end of the controller handle.
    • Repeat the previous opening procedure to open the three plastic clamps at the outside of the left controller handle.
  9. Google Stadia Controller Shoulder Buttons Replacement: step 9, image 1 of 3 Google Stadia Controller Shoulder Buttons Replacement: step 9, image 2 of 3 Google Stadia Controller Shoulder Buttons Replacement: step 9, image 3 of 3
    • Insert a Jimmy into the gap between the front and back cover assembly between the left shoulder button and the charging port at the top edge of the Stadia controller.
    • Repeat the previous procedure at the clamp between the right shoulder button and the charging port.
  10. Google Stadia Controller Shoulder Buttons Replacement: step 10, image 1 of 3 Google Stadia Controller Shoulder Buttons Replacement: step 10, image 2 of 3 Google Stadia Controller Shoulder Buttons Replacement: step 10, image 3 of 3
    • Insert a Jimmy into the gap between the front and back cover assembly at the right edge of the right controller handle.
    • Repeat the previous opening procedure to open the three plastic clamps at the outside of the right controller handle.
  11. Google Stadia Controller Shoulder Buttons Replacement: step 11, image 1 of 2 Google Stadia Controller Shoulder Buttons Replacement: step 11, image 2 of 2
    • Insert a Jimmy into the gap between the front and back cover assembly at the inside of the right controller handle.
    • Repeat the previous opening procedure to open plastic clamps at the inside of the left controller handle.
  12. Google Stadia Controller Shoulder Buttons Replacement: step 12, image 1 of 3 Google Stadia Controller Shoulder Buttons Replacement: step 12, image 2 of 3 Google Stadia Controller Shoulder Buttons Replacement: step 12, image 3 of 3
    • Insert a Jimmy into the gap between the front and back cover assembly at the bottom edge of the Stadia controller right to the headphone jack.
    • Repeat the previous procedure at the clamp left to the headphone jack.
    • Do not try to remove the front cover assembly all the way yet. It's still connected to the rear cover assembly.
  13. Google Stadia Controller Shoulder Buttons Replacement, Unfold the front cover assembly: step 13, image 1 of 3 Google Stadia Controller Shoulder Buttons Replacement, Unfold the front cover assembly: step 13, image 2 of 3 Google Stadia Controller Shoulder Buttons Replacement, Unfold the front cover assembly: step 13, image 3 of 3
    • Avoid straining the front cover assembly cable during this step.
    • Carefully lift the front cover assembly and fold it to the left side of the Google Stadia controller.
  14. Google Stadia Controller Shoulder Buttons Replacement, Remove the adhesive tape: step 14, image 1 of 2 Google Stadia Controller Shoulder Buttons Replacement, Remove the adhesive tape: step 14, image 2 of 2
    Buy
    • Use a pair of tweezers to peel the clear protective tape off the ZIF connector on the left side of the rear case.
  15. Google Stadia Controller Shoulder Buttons Replacement, Open the ZIF connector: step 15, image 1 of 2 Google Stadia Controller Shoulder Buttons Replacement, Open the ZIF connector: step 15, image 2 of 2
    • Use the pointed end of a spudger to open the ZIF connector holding the button contact board cable in place.
  16. Google Stadia Controller Shoulder Buttons Replacement, Disconnect the flex cable: step 16, image 1 of 3 Google Stadia Controller Shoulder Buttons Replacement, Disconnect the flex cable: step 16, image 2 of 3 Google Stadia Controller Shoulder Buttons Replacement, Disconnect the flex cable: step 16, image 3 of 3
    • Use a pair of tweezers to carefully disconnect the flex cable of the button unit by pulling it out of the ZIF connector in a flat angle.
    • Separate the front from the rear assembly.
    • Remove the thumbsticks by pulling them straight upwards for an easier handling in case you want to do further disassembly.
  17. Google Stadia Controller Shoulder Buttons Replacement, Unfasten the screws: step 17, image 1 of 1
    • Use a Torx T8 screwdriver to remove the seven 9.6 mm-long screws securing the motherboard assembly.
  18. Google Stadia Controller Shoulder Buttons Replacement, Pry up the motherboard assembly: step 18, image 1 of 2 Google Stadia Controller Shoulder Buttons Replacement, Pry up the motherboard assembly: step 18, image 2 of 2
    • The motherboard assembly is held in place at four points in the controller's rear cover.
    • Make sure to use the long and not the curved edge of the Jimmy during the following prying procedure.
    • Insert a Jimmy next to the right shoulder button and black plastic clamp of the motherboard assembly.
    • Align the long edge of the Jimmy with the corner of the black plastic clamp.
    • Pry up the motherboard assembly by tilting the Jimmy downwards to open the plastic clamp.
  19. Google Stadia Controller Shoulder Buttons Replacement: step 19, image 1 of 2 Google Stadia Controller Shoulder Buttons Replacement: step 19, image 2 of 2
    • Insert a Jimmy next to the left shoulder button and black plastic clamp of the motherboard assembly.
  20. Google Stadia Controller Shoulder Buttons Replacement: step 20, image 1 of 3 Google Stadia Controller Shoulder Buttons Replacement: step 20, image 2 of 3 Google Stadia Controller Shoulder Buttons Replacement: step 20, image 3 of 3
    • Insert a Jimmy at the top edge of the Google Stadia controller just above the charging port.
    • Pry up the top edge of the motherboard assembly by tilting the Jimmy downwards.
    • The charging port is clamped into an opening in the rear cover of the stadia controller. Make sure the charging port is not stuck in its recess during the prying procedure.
    • During reassembly make sure the charging port snaps back into its recess.
  21. Google Stadia Controller Shoulder Buttons Replacement, Insert an opening pick: step 21, image 1 of 2 Google Stadia Controller Shoulder Buttons Replacement, Insert an opening pick: step 21, image 2 of 2
    • Insert an opening pick at the top edge of the Stadia controller to prevent the charging port from snapping back into place.
  22. Google Stadia Controller Shoulder Buttons Replacement, Warning: step 22, image 1 of 2 Google Stadia Controller Shoulder Buttons Replacement, Warning: step 22, image 2 of 2
    • In the following step you'll free the headphone jack from its recess in the controller housing:
    • Avoid prying onto the black plastic cover during the following procedure.
    • Pry at the edge of the motherboard instead.
  23. Google Stadia Controller Shoulder Buttons Replacement, Insert a Jimmy: step 23, image 1 of 2 Google Stadia Controller Shoulder Buttons Replacement, Insert a Jimmy: step 23, image 2 of 2
    • Insert a Jimmy into the gap between the rear cover and the motherboard left of the headphone jack.
  24. Google Stadia Controller Shoulder Buttons Replacement, Pry up the motherboard assembly: step 24, image 1 of 2 Google Stadia Controller Shoulder Buttons Replacement, Pry up the motherboard assembly: step 24, image 2 of 2
    • Pry up the motherboard assembly by tilting the Jimmy downwards.
    • The headphone jack is clamped into an opening in the rear cover of the controller. Make sure the headphone jack is not stuck in its recess during the prying procedure.
    • During reassembly make sure the headphone jack snaps back into its recess.
    • Do not try to remove the motherboard assembly all the way yet. It is still connected to the rear cover by the battery cable.
  25. Google Stadia Controller Shoulder Buttons Replacement, Lift the motherboard assembly: step 25, image 1 of 2 Google Stadia Controller Shoulder Buttons Replacement, Lift the motherboard assembly: step 25, image 2 of 2
    • Carefully lift the left edge of the motherboard assembly in order to access the battery connector.
  26. Google Stadia Controller Shoulder Buttons Replacement, Separate the motherboard assembly: step 26, image 1 of 3 Google Stadia Controller Shoulder Buttons Replacement, Separate the motherboard assembly: step 26, image 2 of 3 Google Stadia Controller Shoulder Buttons Replacement, Separate the motherboard assembly: step 26, image 3 of 3
    Buy
    • Use a pair of tweezers to disconnect the battery cable from the motherboard.
    • Separate the rear cover from the motherboard assembly.
  27. Google Stadia Controller Shoulder Buttons Replacement, Remove the shoulder buttons: step 27, image 1 of 3 Google Stadia Controller Shoulder Buttons Replacement, Remove the shoulder buttons: step 27, image 2 of 3 Google Stadia Controller Shoulder Buttons Replacement, Remove the shoulder buttons: step 27, image 3 of 3
    • Place the Google Stadia controller on your work surface with the charging port facing towards you.
    • Press both trigger buttons at the same time and the shoulder button piece will fall off the motherboard assembly.
    • Remove the shoulder buttons.
Dominik Schnabelrauch
209,969 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,892 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 22
All Time: 352
