Gourmia GAF536 Handle Replacement
  1. Gourmia GAF536 Handle Replacement, Handle: step 1, image 1 of 2 Gourmia GAF536 Handle Replacement, Handle: step 1, image 2 of 2
    • Make sure the device is turned off and let it cool down.
    • Remove the basket and tray from your air fryer.
  2. Gourmia GAF536 Handle Replacement: step 2, image 1 of 3 Gourmia GAF536 Handle Replacement: step 2, image 2 of 3 Gourmia GAF536 Handle Replacement: step 2, image 3 of 3
    • Locate the screws inside the basket.
    • 4x PH02 Screws: 15mm x 5mm
  3. Gourmia GAF536 Handle Replacement: step 3, image 1 of 3 Gourmia GAF536 Handle Replacement: step 3, image 2 of 3 Gourmia GAF536 Handle Replacement: step 3, image 3 of 3
    • Once the screws are removed separate the handle from the basket.
    • Locate the single screw on the handle.
    • 1x PH02 Screw: 15mm x 5mm
  4. Gourmia GAF536 Handle Replacement: step 4, image 1 of 3 Gourmia GAF536 Handle Replacement: step 4, image 2 of 3 Gourmia GAF536 Handle Replacement: step 4, image 3 of 3
    • Remove the screw.
    • Gently pull on the handle with the force needed.
  5. Gourmia GAF536 Handle Replacement: step 5, image 1 of 1
    • After following these steps you will successful remove the handle.
    • Make sure you have all the equipment when going to replace the handle.
3 other people completed this guide.
1 Guide Comment
Surprised they dont do a recall! The screws can potentially work itself out and unto the food
Jo Avridge - Reply
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 92
All Time: 1,138
