Governor Adjustment
  1. Governor Adjustment, Governor Adjustment: step 1, image 1 of 3 Governor Adjustment, Governor Adjustment: step 1, image 2 of 3 Governor Adjustment, Governor Adjustment: step 1, image 3 of 3
    • Before starting, make sure the engine isn't running and is not hot.
    • Using needle-nose pliers, carefully unhook the spring from the end opposite the air filter.
  2. Governor Adjustment: step 2, image 1 of 1
    • Use the needle-nose pliers to either lengthen or shorten the hook at the end of the spring.
    • If your engine is stalling or refusing to start, try shortening the spring. This will enable more fuel to reach to engine at idle. If the engine is bogged down when running and you hear liquids splashing, try lengthening the spring.
  3. Governor Adjustment: step 3, image 1 of 1
    • Carefully re-hook the spring on the arm it was disconnected from.
Aaron Correya
239 Reputation
2 Guides authored
Cal Poly, Team S25-G15, Maness Spring 2018 Member of Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
4 Members
7 Guides authored
2 Guide Comments
Wow, I'm very grateful.
Bradley Earnest - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 37
All Time: 2,960
