GravityLight Dial Replacement
  1. GravityLight Dial Replacement, Removing the Front Panel: step 1, image 1 of 2 GravityLight Dial Replacement, Removing the Front Panel: step 1, image 2 of 2
    • Flip the GravityLight on its back and place it on a sturdy surface.
    • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
  2. GravityLight Dial Replacement, Opening the Device Housing: step 2, image 1 of 1
    • Some of the internal pieces may loosen or fall out during disassembly.
    • Firmly grasp both parts of the GravityLight body and pull them apart.
  3. GravityLight Dial Replacement, Isolating the Front Panel: step 3, image 1 of 1
    • Take the thinner of the two parts, the front piece, and place it face down on a sturdy surface.
    • Ignore the back piece for now, but keep it in a safe place.
  4. GravityLight Dial Replacement, Popping the Dial out: step 4, image 1 of 2 GravityLight Dial Replacement, Popping the Dial out: step 4, image 2 of 2
    • Use two hands to push the dial tabs inward, towards the center of the dial.
    • Push the tabs downward and through to the other side of the casing.
    • Flip the front panel over.
  5. GravityLight Dial Replacement, Removing the Dial: step 5, image 1 of 1
    • Fully remove the dial by pulling it out from the front.
Michallynn Hoffman
317 Reputation
3 Guides authored
Cal Poly, Team 12-2, Forte Fall 2014 Member of Cal Poly, Team 12-2, Forte Fall 2014
CPSU-FORTE-F14S12G2
5 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 870
