GravityLight LED Replacement
  1. GravityLight LED Replacement, Removing the Front Panel: step 1, image 1 of 2 GravityLight LED Replacement, Removing the Front Panel: step 1, image 2 of 2
    • Flip the GravityLight on its back and place it on a sturdy surface.
    • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
  2. GravityLight LED Replacement, Opening the Device Housing: step 2, image 1 of 1
    • Some of the internal pieces may loosen or fall out during disassembly.
    • Firmly grasp both parts of the GravityLight body and pull them apart.
  3. GravityLight LED Replacement, Removing the Back Panel Screws: step 3, image 1 of 1
    • Place the back panel, the larger of the two pieces, on a sturdy surface with its back down.
    • Unscrew the two 2cm Phillips 00 screws on the inside of the back panel.
  4. GravityLight LED Replacement, Removing the LED Housing: step 4, image 1 of 2 GravityLight LED Replacement, Removing the LED Housing: step 4, image 2 of 2
    • Hold the LED housing in your hand, but do not separate it too far otherwise you will tear the wires.
    • Lift the LED housing away from the back panel.
  5. GravityLight LED Replacement, Remove the White Gear from the LED Housing: step 5, image 1 of 2 GravityLight LED Replacement, Remove the White Gear from the LED Housing: step 5, image 2 of 2
    • Grab the outside of the large, white gear in the LED housing and pull the gear out of the housing.
  6. GravityLight LED Replacement, Position the LED Housing: step 6, image 1 of 1
    • Set the LED housing flat on a sturdy surface so that the back of the LED and the wires are exposed.
  7. GravityLight LED Replacement, Cut the Wires: step 7, image 1 of 1
    • Place the GravityLight's back panel aside.
    • Use the Flush Wire Cutter to cut both the purple wire and the red wire that connect to the LED.
  8. GravityLight LED Replacement, Bend the LED Leads: step 8, image 1 of 1
    Tool used on this step:
    Buy
    • Take tweezers and bend the leads (the silver wires coming out of the bulb) so that the leads are straight.
    • The straight leads will make the LED easier to take out.
  9. GravityLight LED Replacement, Remove the LED: step 9, image 1 of 1
    • Flip the LED housing over.
    • Pull the LED out with tweezers.
  10. GravityLight LED Replacement, Soldering the New LED: step 10, image 1 of 1
    • For reassembly: Flip the LED housing back over.
    • Put the new LED in its spot. Solder the red wire and the purple wire back onto the new leads.
    • Make sure that you pair each wire to the correct lead. If the LED still does not light, switch the wires on the leads.
    • For information on how to solder look here: How To Solder and Desolder Connections
Brian Gouldsberry
201 Reputation
2 Guides authored
Cal Poly, Team 12-2, Forte Fall 2014 Member of Cal Poly, Team 12-2, Forte Fall 2014
CPSU-FORTE-F14S12G2
5 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 17
All Time: 784
