Greist Buttonholer Fork Arm Spring Replacement
  1. Greist Buttonholer Fork Arm Spring Replacement, Unscrew the Lower Hook Holding the Spring: step 1, image 1 of 3 Greist Buttonholer Fork Arm Spring Replacement, Unscrew the Lower Hook Holding the Spring: step 1, image 2 of 3 Greist Buttonholer Fork Arm Spring Replacement, Unscrew the Lower Hook Holding the Spring: step 1, image 3 of 3
    • Unscrew the screw located underneath fork arm using a Flathead screwdriver.
  2. Greist Buttonholer Fork Arm Spring Replacement, Remove the Lower Hook: step 2, image 1 of 3 Greist Buttonholer Fork Arm Spring Replacement, Remove the Lower Hook: step 2, image 2 of 3 Greist Buttonholer Fork Arm Spring Replacement, Remove the Lower Hook: step 2, image 3 of 3
    • Raise the fork arm so that it is parallel with the upper hook.
    • Turn the lower hook towards you from the bottom, and remove.
  3. Greist Buttonholer Fork Arm Spring Replacement, Replace the Spring: step 3, image 1 of 2 Greist Buttonholer Fork Arm Spring Replacement, Replace the Spring: step 3, image 2 of 2
    • Remove the old spring from the hook.
    • Add the new spring to the hook.
Michael Sykes
552 Reputation
5 Guides authored
USF Tampa, Team 3-6, Brown Fall 2014 Member of USF Tampa, Team 3-6, Brown Fall 2014
USFT-BROWN-F14S3G6
5 Members
8 Guides authored
One Comment
Will the spring look distorted if it needs replacing?
Sarah Turnbull - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 276
